vrtical
Doug AI
GSMNP, TN
Fords
Folks see the note about the rear locker being available in all 4 wheel drive modes? Works for me. It also says something about the rear locker possibly being engaged automatically in certain modes (pg 15). Do others read that the same way? I don't care for that. There are some times when the rear locked will create handling issues that you can otherwise avoid. Seen this before.
front and rear locker have their own button, but yes some GOAT modes with activate the rear locker.
Rayder
Brighton,MI
F-150
Does Apple CarPlay not come standard on all models? I was under the assumption that it did but I see an asterisk on p5 related to CarPlay / Android Auto for "if equipped".
It does, but to get the wireless CarPlay you need the Mid package. On the base you need to plug your phone in.
NC_Pinz
Central NC
I don't are for the last part. The scenario that comes to mind are slick side slopes. I've watch multiple vehicles slide into a tree at the apex of a sloping curve, while I just disengage and cruise right through. Hopefully you can turn it off even if it engages. Also true for tight trail turns...sometimes you need to turn off your lockers to tighten the turn a bit more.
Mdemieville
mark
2011 Lincoln MKZ hybrid
From what I was told at Mammoth is that if the goat mode locks either diff you can reach up and unlock each or both diffs.
TonyWonder
AL
2011 Nissan Altima
This is not correct. Wireless apple carplay is part of the sync4 system which is standard on all models.
Ford Bronco 2021 Bronco Quick Reference Guide! PDF đź“„ 1614376770727
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
Haven't tried to print, but a moderator on BroncoNation posted this version, that I think would work better:
Out of curiosity, did the BN moderator credit Bronco6G? Cause that just links to the cropped version I posted here.
Don't really care, just wondering.
DryYourTears
Josh
NoVa
2022 Defender, 51 Ford F1, motorcycles
Very cool document overall! I def sturdied every sentence.
Some info about the manual would be nice, especially the crawler gear, as it’s a new feature. Like the fact it has synchros, which we only know from a KOH video.
Plus the use of the collar, like how you have to lift it to go to reverse or crawler gears. Should be obvious but so should the +/- buttons on the auto shifter lol.
I wonder if they just consider the shifter collar a normal thing not worth mentioning. The Euro-spec Ecosport I drove with a manual had that, as did the manual Fiat Punto I drove. I assumed it's something everyone went to at some point after the last manual I owned that was from '07.
shieldsy
'79 Bronco XLT
On your link (originally posted in 2019), the visual in the article shows Ford still listening to the same song (I KNOW the marketing team wouldn't recycle 2+ year old content for the coolest new vehicle on the planet, right?!).
I wonder if this will be the only song that the Bronco will be able to play? :)
Ford Bronco 2021 Bronco Quick Reference Guide! PDF đź“„ 1614379031806
Used2jeep
Massachuvian
2007 Crown Vic P71
Remaster? I'm reaching here...
flatlander40
This is great news. I never owned a vehicle with more than 18. Tho with the presumably low tier gas mileage it'll go just as quick. Still happy they put a bigger tank in there
That’s funny because I’m disappointed.
My last two vehicles I’ve owned had 36 gallon tanks LOL
mikeheel
MIke
Chapel Hill, NC
lovelikehateblog.wordpress.com
Azure Gray Wildtrak, BWM K1600B, Ford Maverick
Headsong
B Wants A Bronco
San Diego, CA
2012 Nissan Frontier PRO-4X; 2002 BMW 530i
I’ve seen the collar used in videos but have never driven one myself. I prefer the method used in VW/Audi and others where you push in/downward on the shifter to shift into reverse. Just looks better because there is no collar. But obviously the collar isn’t a dealbreaker for me lol.
