Stimpy
Jared
MD
F-150
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Nice find.
8780 - 4977 = 3803
So you are not carrying more than one adult and one child, plus gas without going over towing 3500 lbs. (So I guess I'll be going over.)
Pocobronco87
Matt
Port Coquitlam Canada
RAV4 2001
So if I am not towing can I load bronco up to 8000 lbs then how do I calculate gwvr
2Jeeps&PatriotX1
Denver, CO
'23 4dr Badsquatch, ā€˜05 LJ & ā€˜17 F150
Based on this...figure 4dr BL, 2.7, hardtop, lux will be around 5300lb curb weight and with my 3,395lb offroad camper, 2 adults (300lb total), 2 dogs (140lb total), Iā€™ll be 295lbs over the GVWR. Complete BS. It states max tow rating is with driver/passenger both weighing 150lbs and varies based on configuration.
So I want to know what 4dr trim with the 2.7 gets you that max 3,500 towing, because the way I see it is if the 4dr BL w/ 2.7 comes in at lets say 5200lb curb weight with soft top and standard package, add driver/passenger 300lbs, that takes you to 5500lbs and tow rating of only 3,340lbs.
Lakelife36
Ben
Interior of BC
Am I giving the ShOrT WhEeLbAsE cAnT tOw crowd too much credit if I believe that they will figure out that a 2 Door with its lower curb weight will actually be able to tow more than a 4 Door much of the time?
Lakelife36
Ben
Interior of BC
That is a really good point. If you assume that a driver weighs 150lbs, then a base would have to have curb weight no higher than 5090lbs and a Black Diamond would have to have curb weight no higher than 5190lbs.
Lakelife36
Ben
Interior of BC
Nope there will still be a GVWR that as far as I know has not yet been released but is speculated to be a hair under 6000lbs. The loaded weight of your vehicle can never exceed GVWR. GCWR is the loaded weight of your vehicle and trailer combined, which is a different limitation.
dmtndan
1991 Silverado, 2014 Malibu
I still feel like the sticker ā€œ3500ā€ itā€™s going to go up just a little, but the actual will stay the same.
Meaning, like in the f150 the max towing vehicle is an odd configuration that never gets bought.
Lakelife36
Ben
Interior of BC
In this vehicle it likely would. Say if it was a 4 Door non-sasquatched BB, BD, or OBX with a slightly beefed-up rear suspension including disconnecting swaybar and a Class III hitch?
broncoskip
Broncoskip
Maryland USA
F-150
We should be able to get more armor and accessories if we opt out of the tow package...
jaruss01
NJ
Isnt this good news? Everyone was thinking the GVWR was like 7,000 lbs to match the wrangler class. People were freaking out on whether they could even load up the cargo hold and add a roof box for a family of four on a badlands.
etmccaus86
Evan
Motor City
'22 BaseSquatch
Sort of unrelated to towing a trailer, but nice to see confirmation of "four-down" flat tow capability on both transmissions, especially given some of the most recent talk from the allegedly well-trained reps suggested otherwise.
