2021 base with keypad entry, where do you find the keypad code?
Sail
Many
I’ve searched thru my stuff but can’t find the code….also, what are these? have 2 of em…..
Ford Bronco 2021 base with keypad entry, where do you find the keypad code? 668C3FFD-CA72-4C78-BD9A-8B8F05178150
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
That looks like the pieces off the top of the windshield, where you'd mount a roof rack?
Ford Bronco 2021 base with keypad entry, where do you find the keypad code? 4646127B-4CC7-468F-B8C9-ADC37B2687BD_1_201_a
Bschurr
NY
The master code is on a piece of paper affixed to the front of the fuse box located behind the driver’s side panel under the steering wheel. Pull down from the top to release the clips and the whole panel has a hinge on the bottom.
Sail
Sail
Many
Thanks!
yes I have a factory roof rack
Fuzion2Bronco
Asher
Base Sasquatch
For My Fusion, it was in the Manual.
Sail
Sail
Many
man, I’m not finding the fuze panel under there. I layed down there for some time looking… I have a manual transmission if that makes a difference.
zedster
Las Vegas
'21 Bronco 2 dr Badlands SAS, '22 F150 PowerBoost
Under the steering wheel there is a panel that pulls down. On mine the security code card is there by what I recall was a fuse panel? I do not have the keypad however.
Thrash Metash
Howard
Basesquatch
Mine was on a card in a plastic bag in the glove box. It's pretty obvious once you see it.
Sail
Sail
Many
Well dang, nothing under the steering wheel, no card anywhere and I looked thru all my paperwork.
thanks y'all
Ford Bronco 2021 base with keypad entry, where do you find the keypad code? FFF31B88-91FE-42B4-A768-AAE2CDA88617
zedster
Las Vegas
thanks y'all
Ya mine is by the fuses. Again I do not have the keypad.
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
Doesn't matter if you find it or not. The keypad isn't like the old hardwired ones. The code on the ecu won't match the keypad. It's programmed like a key. You'll need to contact your dealer to either find the code or have them reprogram it.
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
Look VERY carefully through your documentation that the dealer probably left in your glovebox.
You are looking for a white card the size of a credit card. Hard white plastic.
It will have 3 bar codes (left to right) on the top 2/3s of the card and the text "ACCESS CODE - XXXXX" just below the 3rd row of bar codes.
zilstershiner
Zach
Oklahoma
1999 Jeep Wrangler, 2007 Jeep Wrangler
I found my code card in the center console. There’s a liner at the bottom of the center console it may have slipped under?
