2 door side Molle panels
Blaven
Pennsylvania
superchar1982
Charlene
west sacramento
2024 2dr bronco 7spd , 2022 911
I just installed the broaddict ones yesterday to keep thieves from grabbing stuff. They seem sturdy and install was easy. Got them pretty cheap on eBay too. How to you plan to keep them from flying out the back? I stay clear of every truck I see that has a dog loose in the bed.
Ford Bronco 2 door side Molle panels IMG_8621
Blaven
Blaven
Pennsylvania
I have tie downs for them in the middle of my rear seat delete so they can't get out the back due to the leash length. But the leashes are still long enough that they can stick out the side as to not make them too uncomfortable.
With that said, do you have to unbolt them everytime you put on and take off the top? That was another one of my concerns.
jbacon47
Josh
Seattle
2022 Ford Bronco BadLands manual 2-door
DV8 makes one, and I’ve seen a few other unique options on amazon/ebay.
OmahaKevin
Kevin
Omaha
2012 Mustang GT, 2023 OBX
I have the Broaddict on 4 door. I can easily reach the bolts for my hard top. I have the Rockworkx bolts so no wrench required.
superchar1982
Charlene
west sacramento
With that said, do you have to unbolt them everytime you put on and take off the too? That was another one of my concerns.
Not sure. my top is off for the summer. In the fall I plan to take them off when the top goes back on. Not a fan of the visibility being blocked by the panels.
KABQ
Aaron
Albuquerque, NM
I have the Broaddict ones on my 2 door. I only installed the driver's side since I like being able to see the rear passenger blind spot. Install is pretty easy even with the top on if you have flex head box end wrenches.
Be aware that there are two versions: the older version only has rectangular cutouts, the newer version has holes for Grip Fists. Unfortunately I got mine before the newer version came out.
TheShark
I've got the Broaddict's, install wasn't bad but then I have the mod top with the removable rear windows which makes it much easier. I've since removed the passenger side because of the obstructed view.
Ford Bronco 2 door side Molle panels DC074898-5D7A-4A59-9C09-C4388DF23A77_1_105_c
CliffordTheBigRed
Hilary
Golden
Chrysler Pacifica
Let me know if you have any questions. New customers can use the discount code NEWGLUE15 at checkout for 15% off your order.
Any chance you could make these for outside the windows?
