2-Door Rear Window Molle Panel Storage
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
Made of Steel,textured black powdercoat over durable zinc primer finish.
No drilling required,Bolt on factory holes.
Designed to maximize the storage space in the rear cargo area.
Include both sides(left & right).
Original price: $269.99
Limited Time Offer: $139.99
🛒🔜Click here and Learn more about it:2-Door Rear Window Molle Panel Storage
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
Do you need to remove the top the install it?
I assume the top can be removed after installation?
BA OffRoad
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
The molle of the tail window needs to borrow the mounting screws of the hard top, so it will be easier to install if you remove the hard top when installing. Removing the top is also done by unscrewing the screws at the bottom.
raqball
Kris
WA
2023 Ford Bronco Badlands 2DR
I assume this can be installed and used if topless? I keep my hardtop in storage until winter and just roll topless all the time..
BA OffRoad
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
Can be used after removing the top
BA OffRoad
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
