4 Door Rear Window Molle Panel System
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
Fitment: Rear window flank panel is custom fit for Bronco 4 door 2021-2024.
Quality construction: Molle panel made from durable steel construction, the hardtop rear window molle panel features a black coat finish and is specially treated to resist scratches and blemishes.
Customizable Storage: Molle panels for vehicles designed to maximize the storage space in the trunk by utilizing the rear window area. Store those larger bags, fire extinguisher, winch rope or that shovel you need for setting up a proper camp.
Simple Installation: There is no drilling or cutting need. Place the panel around the rear window and align it to the factory mounting holes. Then fix it with basic hand tools using your factory bolts. Note: The system is not suitable for the 2-Door bronco.
Package Include: 2 pcs left and right window molle panel + all hardwares.
🛒🔜 Click here and Learn more about it:
https://broaddict.com/products/4-door-rear-window-molle-panel-system?_pos=1&_sid=683b03b47&_ss=r
mjp2
NJ
2021 Cyber Yellorange Bronco Badlands
Great discounts all over your site today. Just placed my order.
mjp2
NJ
Molle panels arrived faster than expected! I finally had time to install them 2 days ago and it took maybe 45 minutes from start to finish, which included gathering tools and putting everything away. Adjustability in the mounts made it easy to ensure there was no rubbing anywhere and the trim panels reinstalled without issue. Always nice to have a product that works even on the early 2021 models that lack all of the rear rollcage mounting points.
Great quality, no rattles, easy install, and fantastic pricing. There's nothing not to like. :)
jclark
Jeanette
Mid-Michigan
Revisiting this thread, as I'm looking for molle panels for the 4-door that fit below the rear roll bar, but do not require use of the hard top screws to secure (since I have a hard top and want to be able to remove time to time). So, that also means that I need access to those bolts with the panel installed, and most likely holding various gear in place. The Broaddict offering and Turn Offroad both seem to use the hardware for the soft top behind the side trim panel (and not the hard top mounting bolts). Any others for consideration?
