4 Door Rear Window Molle Panel System
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
Fitment: Rear window flank panel is custom fit for Bronco 4 door 2021-2024.
Quality construction: Molle panel made from durable steel construction, the hardtop rear window molle panel features a black coat finish and is specially treated to resist scratches and blemishes.
Customizable Storage: Molle panels for vehicles designed to maximize the storage space in the trunk by utilizing the rear window area. Store those larger bags, fire extinguisher, winch rope or that shovel you need for setting up a proper camp.
Simple Installation: There is no drilling or cutting need. Place the panel around the rear window and align it to the factory mounting holes. Then fix it with basic hand tools using your factory bolts. Note: The system is not suitable for the 2-Door bronco.
Package Include: 2 pcs left and right window molle panel + all hardwares.
CalvinT
Calvin
Phoenix, AZ
Do you have to take the top off to install these?
BA OffRoad
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
jag2440
Orego0n
2022 Ford Bronco Outer Banks
Look great, where did you get them from?
projectbadlands
Robert
Los Angeles
2018 Colorado ZR2
So.......... how exactly does one reach the bolts to remove the hard top?
cr117
PNW
Bronco, EV6
and your arms are small enough to pass through the molle panel holes?
I can reach the front bolt by wrapping my arm around the outside between the roll bar and the window.
projectbadlands
Robert
Los Angeles
2018 Colorado ZR2
Is there enough space to get a tool in there to turn the bolts quickly or is it 2 ratchet clicks at a time?
cr117
PNW
Bronco, EV6
I have the Turn Offroad molle panels (very similar design) and I don’t have an issue getting a few clicks with the ratchet a couple times before I can just unscrew it the rest of the way by finger.
BA OffRoad
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
BA OffRoad
BA OffRoad
New York
www.broaddict.com
Bronco Badlands
