2 7L twisted intake tube
ffdemoss
Northwest Arkansas
2009 F250, 2017 Fusion, 2014 Escape, 2005 LJ, 1968 M715
Need another 2.7L owner to post a pic of their passenger intake tube to see if it matches mine. Doesn't look right, but want to make sure.
Ford Bronco 2 7L twisted intake tube 20211107_124044
slohatch
Daniel
2026 Bronco Raptor
I will look at mine when I get home in a few
Bronco cat
Carl
Morgantown wv
‘20 Explorer ST, ‘19 GT350, ‘21 Bronco Sport
If you want to get the kink out loosen the hose clamp and rotate the sleeve. That is just lazy assembly
ffdemoss
Northwest Arkansas
Yeah, the tube and plastic pipes are "keyed" to some extent. I'm thinking it might be 180° out. Just wanted to verify what it's supposed to look like before I started fiddling with it.
Sneds
Chuck
High Desert
2011 F-250 6.7L TD 4X4, 2021 2D Cactus Gray FE
Mine is the same!
Ford Bronco 2 7L twisted intake tube 20211107_113843_resized
77BroncoTX
2020 F250 FX4
mine is the same.
ffdemoss
Northwest Arkansas
Well, I guess I'll just wait around for the valves to drop now. Thanks for the feedback.
myrealname123
Trent
Monterey, CA
'25 Bronco Badlands
This is not a defect, that's exactly how it was designed.
j_marinelli
Spring Branch, TX.
It is not twisted, looks like the tube creates a vortex with that shape
Reminds me of the good ol' Tornado intake. Anyone else remember those info-mmercials? 😂
Ford Bronco 2 7L twisted intake tube 41ijddey2mL._AC_SX450_
mpeugeot
Those are actually inside the 3.5 intake tubes and the smooth out the airflow, believe it or not.
LAB0035
Lex
2022 Ford Bronco Badlands
They are designed that way to increase air flow
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
Fun fact - my company used to manufacture power plants’ industrial vane controls. Basically like that, but huge. They were used to control air flow rate and velocity.
