2.7l Port Injector Location?
seananigans
Sean
Jersey City
2022 Ford Bronco Wildtrak 2.7l
Hello!
I'm about to have some new port injectors come in. I can't seem to find a diagram of where the port injectors are on the nano. Anyone able to provide some guidance? Is it complicated to swap port injectors? Should I just have my favorite mechanic do it?
Ducati1098
They’re under the intake manifold. Pretty easy to change out if you’re mechanically inclined.
seananigans
seananigans
Sean
Jersey City
Thanks Ducati. Do I have to replace any of the gaskets on the manifold? Or just remove manifold, swap and put back together?
Ducati1098
You should replace them anytime the manifold is off. There’s also some EGR stuff you’ll need to remove in order to remove the manifold which has gaskets also.
seananigans
seananigans
Sean
Jersey City
gotcha. thank you!
Aonarch
Jack Hoff
MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
Any tuning required?
Got a link to the benefits, besides the obvious, assuming they have a better duty cycle and/or flow rate?
