2.3L turbo boost issues
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Maybe 20 years ago. 18-20psi is normal for EcoBoosts. They can easily push over 20psi with just a simple tune, no "mods/upgrades" or "race fuel" required.
I'll have to take your word for it cause I don't have mine to play with yet. But if the OP's will push 18 psi I'm sure his turbo is working!
Autoteknix
Mass
Too Many
Good Afternoon. My base February build 2.3 stick has same issue. Took off electric wastegate controller and wastegate valve is frozen. Got it freed up but didn't last long. Dealer had already cleared "a code" before i took delivery. Hope the backlog for turbo's is short...UGH only 50 miles on it.
BadBradBronco
Brad
South Florida
2015 Explorer
Same for me at 60 miles. 2.3L and got power train failure loss of power message. Brutal.
navi
Navi
CA
73 Bronco
So many bad wastegates. Does the 2.7 use the same part? :confused:
NC_Pinz
Central NC
Seems like from 2.3L stories, the failures are happening very early (i.e. low mileage). Thinking that making it past a couple of hundred miles and you're in the clear.
FourHorses
Four Ford Horses and an Expedition
So I installed a new afe filter a few weeks ago. Next run it felt strong, maybe even a little more peppy.
Wednesday morning I felt I was down on power and throttle response. Boost still hitting 18+ psi. I checked filter last night and it appears seated and fine. Still 100% clean. Still feels down on power. Almost like how eco mode feels. In normal mode though. Everything sounds normal, and you hear the turbo like normal.
2024 2 door 2.3 manual SAS. 10k miles.
Ironically or coincidentally it was at the dealer Tuesday getting the hitch kit installed. They didn’t program it, but that’s a different issue.
thoughts?
