2.3L manual trans plus Sport mode...
arwhite
Allen
New Braunfels, Texas
2019 Ford F150, 2024 Ford Explorer, 2024 Ford Bronco
...is my new normal. What a sweet setup.
If the first Bronco I test drove had been in Sport mode I might have brought it home that day. I didn't know anything about it then and the sales dude apparently didn't either.
If you have the 2.3L with manual transmission and haven't tried Sport mode yet, I encourage you to do so. Very nice throttle response. And you are still in control of the shift points. What's not to like?!
Bikeric
Tulsa
2022 Badlands LUX on 37's
Funny you should mention that, I was just starting to look at that this morning. 🙂
The FP ProCal gives a decent bump in power but you might want to look at other tuning options that can give even bigger gains since Ford took away the Rev Matching feature.
arwhite
arwhite
Allen
I saw where they took away the rev matching. Any idea why they did that?
351W-Bronco
Herb
Southern New Mexico
2023 Bronco,1969 Bronco, 2001 Excursion (7.3L)
I have a 2.3L manual, and while I've been tempted, I'm scared of starting down this endless rabbit hole of improvements. One day...
Herb
+1. One of the best mods, Ford warrantied too!!
Rev matching more fun if you heel toe yourself anyways
I’m more upset about the ASS change than rev matching with ProCal - but yeah.
ASS in a manual is beyond ludicrous
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Huh, ASS doesn't bother me at all, not even in the slightest.
It doesn't even activate unless you put the transmission in neutral and let out the clutch pedal. Basically gives you complete control over it.
On automatic transmissions you have to play footsy with the brake pedal to trick it.
adam1991
VW GTI (2)
or just add the proper harness so that it stays in whatever mode you last had it across restarts.
Bikeric
Tulsa
I can barely walk and chew gum at the same time. My steel toe work boots sometimes overlap between the gas and the brake, so NO WAY I'm "heel toeing" a Bronco :ROFLMAO:
