Dino
Dino
2022 Bronco OuterSquatch
Updated with measurements per your requests:
And if either Sasquatch or stock Badlands are there, this measurement to further confirm lift differences.
Would love to have the true height of the badlands and Sasquatch confirmed to the top of the roof. The Bronco nations dimension table is suspect.
Please measure the girth of the steering wheel. depth of cup holders and length of gas pedal.
these are PARAMOUNT to the buying process.
thanks,
I gotcha, fam.
How high is the seat from the ground? am i jumping in this thing?
Badlands and it was taller than I expected
cargo depth and width because there is still debates on it even though we have seen photos!
I was trying to get them one handed and avoid the direct sun glare
Hey all,
I'm going to an event in MN in about 2 hours. I know there's been 4000 posts about pictures and measurements already, but they're always seems to be something that pops up someone wants /needs.
So, does anyone need any pictures / measurements that haven't already been taken?
Unfortunately, I don't know what Broncos will be there, but it'll do my best to update it when I get there and get what I can.
Edit to add both 4doors, cactus gray FE and A51 Badlands
Had to jet to get back to work, got everything I could, sorry if I missed anything, I tried.
FATHORSE
Stephen
okc
nissan
Can you reach the two door back pillar from the front seat?
HPNQ420
Wauwatosa, WI
'23 Bronco, '19 GTI, '88 R100GS, HPN BMW G/S, 14 JK Rubicon
That might not work for the Sasquatch as the Sasquatch flares are different.
BronchoPeat
Pete
Ohio
www.evergreenclothier.com
'18 Tiguan S w/4motion | '14 Fiesta SE Hatchback
jaruss01
NJ
Can you measure the point of time it will take for me to get my build date?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Ooh that would actually tell us if squatch flares are truly cut out higher. Based off axle to frame differences it's been established squatch is 0.5" taller than all other trims.
Tricky Dick
Dick
PNW
I’ll do so measuring of the flares to solidify this but I believe the Sasquatch flares are actually a slight bit taller. Axle to frame has to have exact parity with the vehicles meaning same motor. The springs are different between 2.3 and 2.7
A good measurement would be from top of tire to the actual pinchweld the flares mount to. You can take from that the true height differences. It should only be the tires changing the height from everything I’ve known, though the shocks are in fact different but only internally and not in length.
The pinch weld measurement would be great but I didn't get that on the BD and OBX to compare. My flare/hub and axle/frame measurements were identical on both. The OBX was a 2.7 and the BD a 2.3.
EvlNvrDys
Hunterdon County, NJ
Is that a stock BD with that much room under the fender?
If it is, I should have absolutely no problem stuffing 295's on my BB build. Haven't seen this pic before... Thanks.
Dino
Dino
Dino
I got that one for you without leaving my desk. Too long.
Bud2020
FL
Badsquatch 2.7 Lux
Picture of firewall, with a banana for reference.
Tricky Dick
Dick
PNW
"pre-production" of course, but yes. Here's the front fender.
Ford Bronco 📐 New 2021 Bronco measurements per your requests IMG_20210502_104736491
