15% OFF Fog Light Kits
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Traveler
Chicago
2023 Wildtrak; 2017 HD FLTRXS and 2008 HD FLSTF
Just ordered a kit for my 2023 with the Capable Bumper! Bought a compressor and mount from you last year. Hopefully these are as easy to install as the compressor was.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
My advice to you is REMOVE YOUR BUMPER. Then it's easy. It's just tight back there and the bumper removes SO EASY.
3 bolts on either side (they are under the plastic cover that surrounds your tow hook). Remove the 3 bolts on each side and you can remove your bumper. DO NOT FORGET to disconnect the wire harness on the driver side that goes to your factory sensors/fogs. There is a plug under the headlight.
The easiest way is grab the plug and pull outwards/down. It's CLIPPED into the felt and you can get a few extra inches by pulling it off the felt.
Then follow our instructions to install the fogs included with the kit, pretty easy. DO NOT forget to attach your wires BEFORE you put the plastic cover back on :) - ask me how I know that lol :)
Traveler
Chicago
Thanks for the additional instructions! It will probably be a while before I can get them installed, but I'm looking forward to it. Should Pair 1 be the inside pair and Pair 2 the outside? I may upgrade bumpers at some point too, so hopefully can move these around later with any applicable brackets.
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
About to pull the trigger on the KR bracket with SAE Pro Yellow and Max Combo for my capable bumper. Not sure if I asked this but does the kit come with the harness to run the SAE's on the OEM fog light switch and Combo's from one of the aux switches?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yes it does. One pair of lights is controlled from the factory fog switch. 2nd pair from your upfitter
Callelk
Larry
Idaho
Would the MAX SAE yellow be any real advantage in snow/fog?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Well they are the brightest fogs. We run SAE Max Fogs on our own truck.
SAE Fogs in White
SAE Fogs in Yellow
Would be an awesome setup
Callelk
Larry
Idaho
SAE Fogs in White
SAE Fogs in Yellow
As opposed to SAE yellow fogs and Max combo? I'm looking for some off-road lights without Pillar or a light bar and yellow fogs for when its snowing. We don't get white-out conditions.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Well you can mix/match what you want.
If you want street legal lights do SAE Fog in white and yellow.
If you want street legal lights AND off-road lights do SAE fog and SAE Combo
Yellow is good for bad weather, but you'll use white more often. Unless you like the look of yellow ALL the time, go with white. Remember it only snows a few times a year right? But some people like yellow fogs all the time. I personally prefer white fogs and would do an SAE Fog in white and yellow, because I have other lights. But yeah for you, go with the yellow then and then the combos for off-road use
Always a tough choice. I have our flush kit so my setup isn't even ideal for me. I have the S3 Max in White Fog and then my 2nd pairs are Driving Yellow and I think combo white.
I could have done the SSC2 Pro in yellow fog, but it's a lot smaller then the S3 and I wanted a BRIGHT light, so i honestly don't use it much.
I might go to our open style bracket and do 2x SS3 Max in Fog (white and yellow) and a 3rd SS3 in Combo (it'll get partially blocked but that's okay, i have tons of additional lighting)
Callelk
Larry
Idaho
Makes sense, white may be better because I would really only want yellow a couple of days a year and the white sae fog's can be used in addition to the combo's for off-road.
Callelk
Larry
Idaho
Placed the order, buy once cry once right............
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
No crying here. You'll love the kit, especially the output of the fogs.
Callelk
Larry
Idaho
Max White SAE Fogs and Max Combos should help with the trails after dark as well as the occasional snow flurries.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Make sure you guys take advantage of these savings while you can! This sales event won't last long.
