Marie_ARB
Marie
Maple Valley, WA
Toyota 4Runner
Ford Bronco Building the Ultimate ARB Front End on Your Ford Bronco: Bumper, Lights, and Air Untitled design (9)
Ready to turn your Ford Bronco into a capable off-road build? The front end is where you should start. A capable front end isn't just about looks; it's about protection, traction, visibility, and having the right tools to get yourself out of a situation when things go sideways on the trail.
We make a full lineup of Ford Bronco accessories that are designed to work together, and in today’s post, we're breaking down four of the big ones: front bumper, off-road lights, and onboard air. If you're building your Bronco for any type of off-road use, this is where we'd start.
Start With the Bumper
Ford Bronco Building the Ultimate ARB Front End on Your Ford Bronco: Bumper, Lights, and Air Untitled design (12)
The factory plastic bumper looks the part, but it isn't built to take a hit from a rock or a tree, and it gives you nowhere to mount a winch or have a recovery point. The bumper is the foundation of the whole front end: it's your protection, your recovery anchor, and the mounting platform for most of your lighting.
For the 2021+ Bronco, you've got two directions to go:
Zenith Non-Winch Front Bumper
The Zenith is our modern, low-profile front bumper for owners who want serious protection and a clean factory-plus look without a winch hanging off the front. It's a full steel replacement bumper with an integrated LED light bar, twin jack points in the center pan, and twin-forged, chassis-mounted ARB-rated 8T recovery points on both sides.
The Zenith comes in two versions to match your flares: wide-flare models, currently $695 while supplies last, and narrow-flare models.
Summit Winch Bumper
If a winch is part of your recovery kit, the Summit Winch Bumper is the way to go. It's our tube-style winch bumper, built from heavy steel and compatible with winches up to 10,000 lb. You still get twin jack points and twin forged, bar-mounted 8T recovery points, plus the same 37" tire clearance and Integrit black finish as the Zenith.
Which one?
It really comes down to one question: are you running a winch, or planning on running a winch? If yes, go with the Summit. If you'd rather keep things low-profile and lean on recovery gear, kinetic straps, and a buddy's rig, the Zenith gives you the protection and recovery points without the extra bulk and weight up front.
Either way, plan for the added front-end weight. A steel bumper (especially with a winch) can settle your front suspension, so it's worth pairing the build with the right springs down the road.
Lighting: Build It in Layers
Ford Bronco Building the Ultimate ARB Front End on Your Ford Bronco: Bumper, Lights, and Air Untitled design (10)
This is where a lot of people stop at "throw a light bar on it" and miss the point. The smart way to light a Bronco front end is in three zones, each doing a different job: the factory fog pocket, the bumper-mounted driving lights, and the high-mounted A-pillar lights. Build all three, and you've got the right tool for every condition: dust, fog, snow, tight trails, and wide-open high-speed runs.
Zone 1: The Fog Pocket
The factory fog location is the easiest upgrade and the one most people do first.
If your Bronco came with factory fogs, the NACHO SAE Plug N Play Fog Light Kit is a true bolt-in swap. Our NACHO Quatro SAE lights fit into the factory pocket using included brackets and OEM connectors that plug straight into the factory fog plug. Each light also carries our Trail Running Light (TRL) feature with an included fuse-tap harness. Pick your lens: white for maximum usable output, or amber, which cuts glare in fog, dust, and snow.
Both of our kits come with our NACHO Quatro Fog Mounts for easy installation.
Zone 2: On the Bumper (Driving Lights)
Both the Zenith and Summit have the ability to mount driving lights. ARB's lighting range covers every preference here:
  • Intensity IQ
  • Intensity Solis
  • Intensity V2
  • NACHO Grande
  • NACHO Quatro
  • NACHO Nano
Have questions about which lights you should get? Drop them below!
Zone 3: Up High (A-Pillar / Ditch)
The last layer is high-mounted lighting that fills in the foreground and the sides, the area your bumper lights can't reach. The NACHO A-Pillar Mounts are powder-coated steel brackets that bolt to the factory mounting bosses near the mirror mount. Pair them with NACHO Quatros, Grandes, or TM5s, and you've got ditch lights that light up corners and trail edges without blinding yourself.
Onboard Air: Powers the Locker, Inflates the Tires
Ford Bronco Building the Ultimate ARB Front End on Your Ford Bronco: Bumper, Lights, and Air Untitled design (11)
Onboard air is the connective tissue of the whole build. It's what engages your Air Locker, and it's what airs your tires back up at the end of a trail after you dropped pressure for traction. It'll also run air tools and inflate camp gear. Few upgrades earn their keep in as many ways as a quality onboard compressor.
For the Bronco, both of our kits use an engine-bay mount that's been validated by Ford engineers. This mount is 100% bolt-on to the factory mounting points and supports both the 2.3L and 2.7L engines. Here are the options we offer:
Not sure which one to get? We’re happy to help answer your questions below!
How It All Works Together
That's the whole front end, and the pieces are designed to stack:
  1. The bumper protects the front of the truck and gives you rated recovery points and a platform for your lights.
  2. The lighting turns night and bad weather from a stop into a non-issue.
  3. The onboard air powers that locker and airs you back up to drive home.
Build it in that order, or build it all at once; either way, you end up with a Bronco front end that's genuinely ready for the trail instead of just looking like it is.
Bruno
Bruno
Sierras
Other end of the spectrum
Normalize minimal update of what is actually needed.
On the trail: Because everyone has a winch, and is itchy to use it, you don't need one
Air Compressors: Only need if you do rock crawling, maybe snow & severe mud is an example you need it if not rock crawling but that's about it.
Lights: Prioritize what is functional for daily. "Ditch lights"? Really? Fog lights - yea. Be careful not to be a jerk with a blasting yellow array because you think it looks cool to people outside your vehicle.
Markers: yea why not they look cool and dont bother anyone
Building an "off road Bronco" is one thing, living with it is another and using what you screw onto the front of your vehicle is yet another thing. IMO start with the least and have a plan to update if needed.
Ford Bronco Building the Ultimate ARB Front End on Your Ford Bronco: Bumper, Lights, and Air 1782343887761-5d
Bronco Toad
Todd
Central Ohio
2022 Bronco Badlands 4dr Cyber Orange
I would love to have this bumper for our farm duties.
I do find my ditch lights have saved me from deer standing close to the road and I think the Summit bumper would be able to take a deer hit if one occurred. I have definitely been sideways missing deer so save some of our vehicles.
NMWildtrak
Keith
Rio Rancho, NM
2022 Wildtrak
Why is the narrow flare Zenith bumper more than twice the price of the wide flare? The pricing you have on the wide flares is very competitive and had me seriously considering (my bronco is actually getting a new bumper due to an accident) but I have the narrow flares on my Wildtrak, and I like the narrower profile in front, just not willing to pay ADD (who makes more desert running style bumpers for my Wildtrak) pricing for an ARB.
Oilbrnr
Scottsdale, AZ
'97 factory locked LX450, '16 Power Wagon w/FWC, '25 Bad/Sas/7MT
You come out West and log a couple hundred miles of washboarded, rock loaded roads, you'll be wishing you'd have lowered your tire pressures.
But you obviously have more off-road experience than I do.
MadMan4BamaNATL
Ray
Atlanta
Dude stop talking.
You need to air down any time you leave a fire road for a number of reasons and if I have to explain these to someone, they've never been wheeling.
Save your rig, your back, and the trail. You may also prevent a puncture of a tire, so this is a PSA for all who venture to this thread to ignore your misinformation filled comment.
If someone doesn't off-road their off-roader, they honestly have no need for this thread or anything from ARB.
ARB gear is not for the poseurs.
MDrums
Tampa
Bronco Raptor
Hi ARB...so $900 plus for a twin cylinder air compressor?!?!...... NO THANKS. Now before you defend your greed snatching price I've owned 2 ARB twin compressors before in past Jeep builds but your price increases are excessive and you've run myself and most all my 4x4 friends away and into other very very nice compressors.
I needed a air compressor and really wanted to do another nice concealed custom install on my Braptor however your value is now horrible so I went with Morrflate and got it for 20% off on Amazon shipping direct from Morrflate. I purchased this along with the 4 hose kit and Air Hub to automatically monitor inflate and deflate to the psi I set. I got all this still for $hundreds under just buying your twin compressor.
If I went with your best twin air compressor, mount, manifold, 4 ways hose kit and auto air hub I'd be over $1400!!!!! NO WAY! More than 60% less the Morrflate is THE KING of having air with me for tires and such out on the trail.
I want companies to make money however the vast amount of GREED in your pricing for what your product is ( it is very nice and good) makes for a product that no longer is as needed as it once was due to competition on the current market that is only getting better at far less cost.
Your CFO and head of sales need to have a serious meeting about pricing and profit you need to operate as a company. I do not believe your pricing is sustainable for future success.
swamp2
JMHO but that's a hideous front bumper and lights...
Valhalla
Valhalla
Chattanooga Tn
I love mine, but I use it for off highway, there compressor is too high... I will shoot it out against mine if they want to give one to me.
Felix808
SRV CA
It would appear ARB has left the chat :unsure: But if you are still with us, our lockers are electric no $1,000+ air compressor setup needed. But like @MDrums said it just seems so cost prohibitive as I've been shopping for my next compressor.
MDrums
Tampa
Bronco Raptor
Just had my Morrflate twin compressor with Air Hub and 4 way hose delivered. Cost with holiday discount on Prime Day ( still ships direct from Morrflate) was more than 1/2 the cost off of a ARB twin!!! Morrflate wonder wonders and as advertised. Plus some companies make a Molle mount for these style of air compressors so I will be mounting it most likely in the cargo area on some Molle fro Built Right I installed and I will run power from the batter to the back and terminate with some Anderson connectors.
Yeah...ARB has lost their mind with pricing I can see and so many more choices with great quality available now.
MDrums
Tampa
Bronco Raptor
Your compressor will either win or time around the same as a twin ARB filing up tires. There are review comparisons out there with ARB against Morrflate, EZFlate, Napa and others like this on YouTube. I am no longer sure why you'd spend ( just for a twin compressor) upwards of $600-$800 more for an ARB other than it is slightly smaller.
