PTYYDS Wireless Charger Pad with Built-in Dual Silent Fans
ptyyds
Lux Sponsor (Level 2)
Alex
Hey Bronco fam!
Tired of messy charging cables tangling around your shifter? Our Wireless Charging Pad provides a seamless power solution for your truck, offering effortless grab-and-go convenience. Specially designed for 2021-2024 Ford Bronco (2/4-Door Auto), this charger pad is not compatible with Bronco Sport models.
Equipped with dual quiet fans, the unit assists in dissipating heat from both your device and the charging base. This design helps support consistent performance during long drives or in warmer conditions by mitigating heat-related charging slowdowns. Constructed from durable ABS with a non-slip mat, it ensures your phone stays securely in place.
Compatible with a wide range of smartphones, our charger works best with thin cases or without a case for optimal charging efficiency. With the included plug-and-play wiring harness, installation is effortless and entirely non-destructive.
Upgrade your Bronco 👉: PTYYDS Wireless Charger Pad
Y2KFirehawk
PA
2022 Bronco Wildtrak
Ninjak
Miami
This looks interesting. Seems to be a solid product; the reviews are good. Having the fans underneath is a boon. I may need to give this product a try and install it before I go to SuperCell.
mflemon
na
Do you have a version that fits a 2026 bronco where the phone area sits front to back instead of side to side
Rivers90
Ben
Southern California
2 Door Base Sasquatch
For the current price of $75 this looks like a great deal. Wireless carplay or android auto is not really wireless without wireless charging. The fans are a great idea, I have had my phone overheat when driving and I added a USB powered fan to cool my phone so this adding two fans is useful just for the fans alone.
purevil
Orlando
2025 Bronco, 2022 Corvette
2025 models are the same way, & not capable with this.
ptyyds
ptyyds
Alex
This is not for the 2025 Bronco. The 2025 Bronco has a redesigned center console.
Appreciate your feedback! We'll double-check the fitment with our team and update our description.
We don’t have this version yet, but I'll share the demand with our R&D team. We’d love to bring this in the future!
ptyyds
ptyyds
Alex
Appreciate the support, guys!
ptyyds
ptyyds
Alex
25s have the phone area crossways with an automatic., so this should work. If you insist on having a manual you probably have not graduated to wireless phones... J/K.
We hate to disappoint you, but after further checking, this won't work for the 2025-2026 models—even with the side-to-side layout. It won't be able to get power. I'll update the description.
Ninjak
Miami
Purchased one, came yesterday. I will get to the installation this weekend. Maybe tonight?
Came well packaged, has a trim removal tool with it, colour instructions, and a different instruction colour shorthand poster.
The charging block has two fans built in, and it looks solid. So I'll let you know how it goes.
