Administrator
Administrator
Staff member
Doug
Bronco6g.com
The face of a new Bronco variant has now been revealed, thanks to a new prototype caught without its front grille camo.
New Face Uncovered
A Bronco prototype has been spotted —revealing a new treatment to the BRONCO lettering, and a fine grille mesh unlike anything seen on the Bronco since it was resurrected in 2020.
A Move Upmarket?
Prior Bronco press events have suggested that Ford is considering moving the Bronco brand into the Work space, while also considering a move upmarket into a more luxurious Premium space. This Bronco has the same front bumper as the Badlands and Heritage trims—both of which sit above the Outer Banks in the Bronco trim hierarchy. The prototype also shows signs of the Fox shocks from Ford’s HOSS 3.0 set-up, confirming proper Bronco off-road prowess. These details would seem to rule out a Work-level specification, and point to something more upmarket.
A Peek Inside—More Premium Details?
Our initial sighting of this new Bronco trim involved a prototype with a fully-covered dashboard, suggesting some interior changes. This new prototype was driving without any dash-camo, revealing a subtle detail that may also point to a higher-tier trim-level than the Badlands or Heritage. The prototype showcased a dashboard finished in a new material, displaying nice stitching details only found on its top two trims—the Bronco Stroppe Edition and the Raptor. Everything from the Heritage Edition and below doesn't have such detailing, suggesting that this new prototype might be positioned above the Badlands and Heritage Broncos—skewing it toward a more Premium offering. The prototype’s apparent Badlands bones says it will still be formidable off-road, but may get more posh detailing for those that might be considering something a bit more…Land Rover.
New Wheels
We see an all-new wheel design on this Bronco prototype, with a clean, relatively deep-dish six-slot design. The wheels have a new outer rim that looks bead-lock-capable. Ford appears to have done some shaving to the tire’s sidewalls, but we can see that they’re Sasquatch-sized Goodyear Territory RTs.
The front wheel arches are undisguised, but they appear to be graced with new front splash guards that attached elegantly to the trailing edge of the wheel arches, for a sleek fit. There are no running boards on the street-tested prototype, but the track tested-tested prototype appears to be have new side sills that may also serve as rocker guards. Then there are those wrapped rear wheel arches, which remain a mystery. New badges are covered up on the track-testing Bronco’s front fenders.
Articulation/Clearance Testing?
The engineers were caught running the prototype over a particularly punishing track surface, and then over to a set of dips that would challenge wheel articulation and approach and departure angles. The prototype appears to have some green plastic bits screwed onto the undercarriage, perhaps to test for clearances. An engineer appeared to be filming the testing, perhaps for later analysis. It would seem that Ford would have these clearances well worked out by now, so we’re left to wonder if any further suspension or driveline changes may have been employed, which would change the underbody geometry. Ford boss Jim Farley has confirmed that a hybrid Bronco is coming.
There’s still lots to learn about the future trims and special editions planned for the Bronco lineup, but this new prototype has given us our most detailed look yet at what Ford has cooking. Stay tuned for more details, as testing ramps up.
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-1
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-2
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-3
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-4
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-5
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-6
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-8
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-7
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-9
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-11
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-12
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-13
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-14
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-15
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-16
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-17
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-18
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-19
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-20
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-21
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-10
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-22
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-23
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-24
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-25
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-26
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-27
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-28
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-29
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-30
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-31
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-32
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-33
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-34
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-35
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-36
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-37
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-38
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted new-luxury-bronco-trim-39
Rough Rider
2018 Mustang Convertible
Outer banks has the stitched dash pad in 26.
I prefer the 60th grill. The two tone looks nice and I am tired of all the grills being so dark. Having to choose dark grey or black, or choosing stark white is not great.
Spiniker
Andy
Pennsylvania
21 ford bronco
New Face Uncovered
A Move Upmarket?
New Wheels
Could it be a Eddie Bauer edition?
MayhemMike
Mercury
Well if the goal was to make a hideous grill they accomplished that goal. In the photos of the interior that show the sensors I hope one of those sensors was to collect data in order to eliminate the door window rattle at half down position.
Nick72
Nick
North GA
2021 Bronco Base(Traded), 2025 Bronco Outer Banks
Outer Banks had it on 25 models. The center console armrest matches the dash as well.
KillerPenz
North East
Not a fan of the wheels or the grill. Knowing my luck, this will be the only model that they drop a Baby Godzilla in, price tag to start at $125k 🤦‍♂️
Ford needs to wake up and realize with all the price increases since launch, the Bronco is already over priced. So a high end model makes no sense.
solracarevir
Carlos
Puerto Rico
Bronco Black Diamond Sasquatch
I dig the new grille. But My money is on a refreshed trim rather than a whole new trim. If you squint your eyes, looks like a evolution of the Badlands grill? (it's the only one with a lot of small holes)
Other thing that caught my eye is the bigger than usual Gap between the Lower grille fascia and the Capable Bumper. Looks almost like Broncos that got a body lift and they didn't got a bumper relocation kit
Ford Bronco New Top-Level Bronco Model Trim w/ New Grille & Wheels Spotted 1775489692478-gd
Area51BS
Ron
Badlands non SAS 4dr 2.3
Terrible grill and flaps.
CarbonGrayBronco
PA
2024 Bronco Badlands
I noticed the big gap there too.
Wouldn't be surprised if we got entirely new grilles in '27, all of them based on the modular grille design with interchangable inserts.
