Lobo Off-Road
Hemet, CA
lobooffroad.com
All of them
HNT ROCK SLIDERS
hnt-rock-sliders-bronco-4-door-aluminum
Ford Bronco NOW AVAILABLE! Lobo Off-Road HNT Rock Sliders F6-19-241B_F-1200
We've designed our HNT Rock Sliders to conform to our HNT Design Ethos which leans heavily on the side of high clearance and light weight, to protect your Bronco while also trying to avoid contact with terrain which can hinder progress through tough obstacles.
Ford Bronco NOW AVAILABLE! Lobo Off-Road HNT Rock Sliders F6-19-241B_J-1200
These sliders are designed to tuck up as closely to the Bronco's body rocker panels as possible while still providing rock slider and door protection. In designing our ultimate rock slider we fully evaluated whether to attach it to the Bronco's frame via outriggers and frame mounts. Ultimately we decided against it because we felt that the cost in ground clearance and undercarriage snag points wasn't worth it. Instead we focused on engineering the best way to make an ultra low profile (i.e. "High-N-Tight"), body mounted rock slider. The result is a design that we believe is the strongest, most robust and versatile body mounted slider system on the market.
Ford Bronco NOW AVAILABLE! Lobo Off-Road HNT Rock Sliders F6-19-241B_G-1200
We realized that the factory slider mounting points were barely adequate, especially in dealing with the leverage of a slider that has any sort of a rock rail protrusion to it. So we designed all new, multiple mounting brackets and in inner backbone structure that engages along the entire length of the Bronco's rocker area and pinch weld flange.
Ford Bronco NOW AVAILABLE! Lobo Off-Road HNT Rock Sliders F6-19-241B_A-2400
The backbone structure bears the forces of any hits from the rocks and dissipates that load over the entire length of the rock slider, not just at a couple of pinpointed mounting bolts. This strategy greatly increases the rock slider's ability to absorb and deflect hits without the focused damage to the fastener locations that normal body mounted rock sliders can inflict. The outer shell of the HNT Rock Slider fits over the Backbone structure to provide a sleek, faceted slider surface that protrudes slightly outward to protect the Bronco's body and doors from vertical rock faces or trees.
Ford Bronco NOW AVAILABLE! Lobo Off-Road HNT Rock Sliders F6-19-241B_H-1200
These HNT Rock Sliders are made mostly of 3/16" thick steel or aluminum plate, CNC laser cut, precision brake-formed, and professionally fixture welded for a consistent fit and finish. And of course they are Made in the USA. Premium hardware and detailed installation instructions are included. They are available in raw aluminum with exposed welds or a durable multi-stage light-textured black powder coat finish or our Mica Armor Coat (see below).
ALUMINUM OPTION
We offer the HNT Rock Slider in aluminum for weight savings, coming in at a fraction of the weight of comparable steel rock sliders. This makes it much easier for your Bronco to find traction and pull itself up and over obstacles with less stress and possible breakage of drivetrain and suspension components. Light weight is almost a religion to off-roaders who know what excessive weight can do to equipment and the hindrance it can cause on the trail. While aluminum isn't quite as robust a material as steel, we've made up for it in design, with internal gusseting, strategically placed bends and the integration of the Backbone internal structure. But for those who drive their Bronco like a wrecking ball, we still recommend the steel version. The aluminum HNT Sliders are meticulously TIG welded with welds left exposed on the raw, uncoated versions.
OPTIONAL MICA ARMOR COAT
This Lobo Off-Road product is available with our durable Mica Armor Coat finish. Mica Armor Coat is a super durable polyester powder coat finish with excellent weather resistance properties for high performance and architectural applications. It has built-in UV resistance to reduce fade over time, which is especially important for vehicles that spend their time outside and on the trail rather than in the garage. This polyester powder coat is thicker and more durable than typical coatings, better able to resist scuffs, scratches and chipping. Mica Armor Coat is dark gray in color, almost black, with a light 3D Metallic flake. Please allow up to two weeks additional lead time for Mica Armor Coat.
THE HNT DESIGN ETHOS
LOBO Off-Road's proprietary High-N-Tight Design Ethos guides the product development of this and every component in our HNT Series. The HNT Ethos strives to tuck every facet of the bumper, slider, skid or component as close as possible to the vehicle components it protects, in order to yield the maximum clearance possible to slip past the tightest obstacles. While HNT Series components are built to take a hit if necessary, they are designed to minimize the risk of contact in the first place. HNT design language also incorporates low-drag surfaces with ramp angles and facets for guiding the vehicle up and over obstacles when contact is made, rather than hanging up on sharp corners and protrusions. While the HNT Design Ethos is silent on the subject of aesthetics, we believe that adhering to the High-N-Tight philosophy has the unintended consequence of yielding the best looking armor products possible.
Lobo Off-Road
Lobo Off-Road
Hemet, CA
lobooffroad.com
All of them
PLEASE NOTE: After months of design, prototyping and testing, we have commenced our first production run of the 4-door HNT Sliders (2-door will come later this year). We are doing a limited run of 20 sets to start with, which will be ready to ship in mid-April. If you would like to call dibs on a set from this first run, please go to the website and click the "JOIN THE WAITLIST" button (you won't be charged). If you're on the list you'll be notified when we are ready to accept your order, prior to opening up orders to the public. If you have any questions please just ask. Thanks!
Ford Bronco NOW AVAILABLE! Lobo Off-Road HNT Rock Sliders F6-19-241B_L-1200
HalfmuleFarmer
Thomas
2025 Badlands
Very nice. The aluminum will be available in a black finish as well?
Nanook
Jonathan
Raptor, Bronco, Galaxie, Ducati Streetfighter V4S
These are awesome!!! 👏
Ben
Baltimore, MD
2023 Bronco Raptor
Absolutely love these and the whole HNT thought process. I just wish there was a bit more of a step so they’d work for my shorty wife.
ean01
2022 Badlands Sasquatch
HNT ROCK SLIDERS
ALUMINUM OPTION
These look great. On your web page you note that these weigh only 35lbs (impressive). I assume that is per side and for the aluminum version? How does this compare to the steel version? Can you provide more information on how these are mounted? Mounting points? Brackets? Pictures? Lastly, do you have any videos you can share from your prototype testing? It would be great to see the sliders in action.
JSW377
J
25 Bad Squatch
Don't all those holes provide a place where rocks can snag the slider?
I can hear rocks and such dinging my body and those following for weeks after a good mud run… and if you think a simple spray off will get them out of the slider… I’ve got a bridge for sale…
HalfmuleFarmer
Thomas
2025 Badlands
Yeah, I don’t see ‘em snagging on anything, but easy to imagine them collecting a bunch of noisy gravel inside, and then good luck getting it outta there. Maybe they’re open enough on the interior side? Hard to tell from the images.
Lobo Off-Road
Lobo Off-Road
Hemet, CA
lobooffroad.com
All of them
The 35 lbs was just a guess by my marketing guy as we didn't have an actual weight yet, and yes that would be much closer to the aluminum version than the steel ones. Also, the weight shown there is taken from the shipping weight that we enter into the shopping cart program. Note that the dimensions shown there are also pulled from shipping dimensions not actual product dimensions, and all of those numbers were just placeholders too since we're currently offering free shipping so the weight on the website didn't need to be accurate. I'll get both versions weighed soon along with the hardware and note the actual product weights in the product specs. Also I noticed the mounting brackets were missing from the edited product image so I had him add those in, I've updated the image in the original post with it. We'll be putting together more photos and a video soon with a closer look at features, installation, etc.
Desmolicious
SoCal
2025 Bronco HE, MX5
Maybe you’re meant to unbolt them to shake out the gravel and small stones it collects?
