- JJ
- Aug 24, 2021
- 78
- 865
- 3,119
- Westminster, MD
- Website
- www.iagperformance.com
- 2021 Ford Bronco
- Wildtrak
We’re excited to officially roll out our IAG Off-Road Pinch Weld Covers for the 2021+ Ford Bronco, now available for both 2-door and 4-door models.
These are now made in-house here in the USA and designed to clean up one of the most overlooked areas on the Bronco while adding real protection.
PROTECTION + FINISHED LOOK
From the factory, Gen 6 Broncos come with exposed pinch welds that leave the rocker area looking unfinished and vulnerable to road debris, corrosion, and trail damage—especially on Broncos without factory rock rails.
The IAG Pinch Weld Covers:
MADE IN-HOUSE. BUILT TO LAST.
Each set is:
HIDDEN HARDWARE – CLEAN INSTALL
We designed these with a clean, streamlined appearance in mind:
QUICK & EASY INSTALL (NO DRILLING)
Install takes about 15 minutes:
If you’ve been looking for a clean way to protect and finish off your Bronco’s rocker area, this is a simple mod that makes a big visual difference.
SHOP NOW
- Clean up the exposed seams
- Add a finished, OEM+ look
- Provide a protective barrier against dirt, rocks, salt, and debris
Each set is:
- CNC cut from 11-gauge aluminum
- Powder coated black to resist scratches, rust, and corrosion
- Aluminum construction means no rust issues long-term
- Finished with a laser-cut IAG logo for a subtle branded touch
- All primary fasteners are fully hidden on the back side
- Logo plate hardware is minimal and positioned to blend in, not stand out
- Uses existing factory pinch weld holes
- No drilling, no cutting, no special tools
- Basic hand tools only
- Bolt-on and reversible
SHOP NOW
