EZ4X4
Connecticut
www.ez4x4.com
🛠 New EZ4X4 Extreme Tailgate Tables for Bronco – Standard & MOLLE Versions Now Available!
Hey Bronco6G,
We're stoked to finally share our EZ4X4 Extreme Tailgate Tables—a pair of heavy-duty, upgraded workspaces designed specifically for your Bronco. After months of real-world trail testing and refinement, they are officially ready!
These tables are direct bolt-on and drill-free, built to give Bronco owners the sturdiest, most functional tailgate setup available (up to 45 lbs!). Whether you’re cooking, organizing gear, or doing trail repairs, these will hold up.
And don’t forget — Bronco6G members can use code 6GBLKFRI for 20% off.
Extreme Tailgate Table (Dual-Shelf Standard Version)
Our standard Extreme Level Deluxe Tailgate Table transforms the Bronco’s rear door into a solid, dual-shelf workstation.
Ford Bronco New EZ4X4 Extreme Tailgate Tables for Bronco — Standard & MOLLE Versions + 20% Off w/ Code 6GBLKFRI EZ4x4-BroncoTailgateTabl
Key Features:
  • Dual-shelf design for versatile cooking, tools, or work setups.
  • Massive 45-lb load capacity for heavy items.
  • Heavy-duty aluminum with textured black powder coat.
  • Installs using factory mounting points — NO DRILLING REQUIRED.
  • Utility hooks and built-in bottle opener.
  • Folds flat with a low-profile footprint to preserve cargo room.
Ideal for: Camping, tailgating, trail days, road trips, and mobile workstation use.
Extreme Tailgate Table with MOLLE Top Panel (The Gear Boss)
This upgraded version includes everything from the standard model but adds a full, integrated MOLLE steel grid on the top surface. This feature means you can mount gear even when the table is closed.
Ford Bronco New EZ4X4 Extreme Tailgate Tables for Bronco — Standard & MOLLE Versions + 20% Off w/ Code 6GBLKFRI EZ4x4-BroncoMolleTailgateTabl
Additional MOLLE Features:
  • Integrated MOLLE top panel for vertical gear mounting.
  • Mount pouches, tools, first-aid kits, radios, bottles, straps, etc.
  • Gear stays secure whether the table is folded up or fully deployed.
  • Still fully functional as a cooking or work surface when open.
  • Same 45-lb shelf capacity and heavy-duty construction.
Ford Bronco New EZ4X4 Extreme Tailgate Tables for Bronco — Standard & MOLLE Versions + 20% Off w/ Code 6GBLKFRI 5100_4389_Bronco_Molle_Aluminum_Folding_Extreme_Double_Tailgate_Table_Sub_4
🟢 Fitment & Assurance
  • Confirmed Fitment: Fits 2021+ Bronco 2-Door, 4-Door, and ’22+ Raptor.
  • Note: Not compatible with Bronco Sport.
  • Warranty: Includes a 30-day satisfaction guarantee and a 1-year warranty.
  • Support: U.S.-based customer support.
🔗 Availability & Next Steps
You can find more details, pricing, and ordering information on our website.
Drop a comment below if you have any questions about installation, stability, or if you just want to let us know which version you prefer!
Ford Bronco New EZ4X4 Extreme Tailgate Tables for Bronco — Standard & MOLLE Versions + 20% Off w/ Code 6GBLKFRI 5100_4365_Bronco_Solid_Aluminum_Folding_Extreme_Double_Tailgate_Table_Sub_4
EZ4X4
EZ4X4
Connecticut
www.ez4x4.com
First question: Does it rattle? ^^ i see that's answered. CHECK.
Next question: where's it made?
Our products are designed and shipped within the United States and made in a USA-owned factory in China.
wpeen001
William
Lancaster PA
23 Bronco Wildtrak, 11 Focus SES, 22 Jeep GrandCherokee Summit, 93 Dodge Stealth
This looks awesome, especially the one with the Molle, a few questions though
-when opened, is there a way to fold it halfway open easily? Instead of having it fully opened like that, as sometimes space is limited to have the table extend that far out.
-Is the bottle opener have easy access when closed?
-does the top shelf have the ability to lift up while table is out and being used
Looking deeply into the pictures these answer are probably no, but had to ask.
EZ4X4
EZ4X4
Connecticut
www.ez4x4.com
1. The table doesn’t have a halfway-open setting — it opens fully for stability. The good news is it doesn’t need much room. If you can open your doors, you’ll have plenty of space to use the table.
2. The bottle opener isn’t accessible when the table is closed — you’d need to swing one panel open to reach it. We designed it that way intentionally to help discourage drinking while driving.
3. Yes it can!
Great questions!
EZ4X4
EZ4X4
Connecticut
www.ez4x4.com
Any clearance issues with the EZTRUNK installed?
No clearance issues! The Extreme EZTRUNK is designed to work with the seats up or down and uses the existing mounting points in the car to install it.
Tmw94fd
Todd
Tennessee
I currently have the EZTRUNK installed.
Will I have any clearance issues with the tailgate table and EZTRUNK installed?
EZ4X4
EZ4X4
Connecticut
www.ez4x4.com
The products are meant to be used together, so there are no clearance issues if you have both the trunk and tailgate table.
jtgensler
Jamison
Clarion, PA
2022 Bronco
what hardware are you using for install?
one of my biggest gripes with my current table is the hardware sucks & let's it rattle constantly.
EZ4X4
EZ4X4
Connecticut
www.ez4x4.com
We send you all the hardware you need! It's stainless steel bolts that fit with preexisting mounting points on the tailgate. There's no additional noise or rattling caused by our tailgate tables.
