suparee
Lux Sponsor (Level 2)
Renee
CA
suparee.com
Jeep Gladiator JT
Introducing the all-new Recon Series Pod Lights!
The Recon Series is Suparee’s latest compact “scout” light lineup, built from the ground up with the lessons we learned developing the Hyper 5. This time, we pushed even harder on design, testing, and real-world durability.
The lineup comes in two sizes (2 inch and 3 inch), each available in spotlight or floodlight options — so you can dial in exactly what your build needs.
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights Recon 1详情_4
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights 1
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights 3
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights 4
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights 5
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights Recon 1详情_3
Specification in Differences (For per light/each):
Recon 1:
Wattage (W): 20W
Color Temperature: 6013K Flood/6398K Spot
Peak beam intensity: Flood 20700 cd/Spot 144700 cd
Total Lumens: Spot 1056lm/Flood 1736lm
Recon 1 Spotlight:
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights Recon 1聚光(1)
Recon 1 Floodlight:
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights Recon 1泛光(1)
Recon 2:
Wattage (W): Spot 35W / Flood 40W
Color Temperature: 6390K Flood/6430K Spot
Peak beam intensity: Flood 30900 cd/Spot 123200 cd
Total Lumens: Spot 2295lm/Flood 3978lm
Recon 2 Spotlight:
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights Recon 2聚光(1)
Recon 2 Floodlight:
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights Recon 2泛光(1)
Commonalities:
Color: White & Amber
Terminal Connector: DT3
Voltage Rating (V): 12/24V
Average Rated Life (hr.): 50000hr
Lens Material: Hardcoated Polycarbonate
Lighting Modes: Spot(or wide)+ Amber DR
Bezel & Housing Material: ADC12 Powder Coat Cast Aluminum
IP68: Waterproof up to 36 inches for 30 min
IP69K: Pressure Washable: Resistant to water streams up to 1450 PSI
5-year limited warranty
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights 1758540073272-45
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights 1758540125604-2q
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights 1758540407497-f
Ford Bronco New: Recon 1 vs. Recon 2 Supraee Pod Lights 1758540772532-29
Here’s a quick look at how Recon 1 and Recon 2 stack up:
👉 Recon 1: https://suparee.com/ForumRecon1
👉 Recon 2: https://suparee.com/ForumRecon2
(Save 15% when you grab yours through the links above)
Finally, if you have any comments or suggestions, please feel free to discuss with us!
We will upgrade our products from time to time and share with you all.
Best,
Suparee
RedTailHawk
2024 Ford Bronco Raptor
Do they come with mounts for the bumper pods?
Andrew Bynum
Los Angeles
21 Two Door OB Sas V6 AMB
It’s not possible to have enough lights on your Bronco. We need more lights!
NAzHunter
Woody
Northern AZ
Ford F-150 & Explorer
Hey, @suparee, I sent you a dm, can you please reply? Thx!
