120v power port not working
wilmerfjohnson
Wilmer
Moore Twp, PA
2018 Fusion, 2009 Mariner, 2000 Taurus, 1996 Bronco, 1994 F-150, 1988 F-150, 1984 Bronco II, 1978 F-350, 1974 VW Thing
Hi! Tried the 120v power port on the back of the center console for the first time, no power. Searched the Sync manual and read the paper manual, both mention an indicator showing whether the port is on, off, or in fault mode. On and off indicator makes me think there is a switch, but the manuals don't mention a switch. I know the vehicle has to be in accessory mode or running.
Fuse 36 under the hood is not blown.
Any suggestions before I make a warranty appointment?
Thanks!
Theherofails
Thomas
Phoenix
Mine just worked. Make sure you REALLY jam that 12v plug in there good though. Both of my 12v were first time tight, second time alright.. Took a lot of finesse... I'm trying really hard to avoid sexual innuendos here..
Drex
Jake
Ford literature claims it only can support something like 1.4A, if you are trying to charge more than a cell phone, there might be a current limiting circuit to prevent you from over loading it. What are you trying to plug in?
mpeugeot
Don't wax it...
wilmerfjohnson
Wilmer
Moore Twp, PA
Hi - no no, this is not the USB or "cigar lighter" port - it is the 120v AC aka "house outlet"...
I appreciate your responses, makes me think to check all of the cigar.lighter plugs and USB ports.
HotdogThud
mk6 gti, '21 MoarDoor
Why fight it? I mean, put that thing in 4L, get behind it and PUSH.
Theherofails
Thomas
Phoenix
Oooh that thing.
You're limited to 400w total, which at 120v is only a mere 3.3 amps. It's going to work for small to medium sized electronics, but anything with a motor is iffy.
What are you plugging in?
HotdogThud
Oooh that thing.
a microwave oven. gotta keep that coffee hot!
Bob Blaylock
Bob
38°29′ North 121°26′ West
2016 Dodge Dart
According to the advertising material, that receptacle is good for only 400 watts. AT 120 volts, that would be 3⅓ amperes. There are a lot of things you might want to plug into that, that would need more. I wonder if you've tried to plug in something that draws more than that, and triggered whatever overcurrent device (fuse or circuit breaker) is in place to protect it.
Bob Blaylock
Bob
2016 Dodge Dart
A disappointment to me is that 400 Watts is not enough to draw what the better of my two DeWalt battery chargers claims to need, and barely enough to run the lesser one.
Ford Bronco 120v power port not working z2021-11-06_17.54.28
Ford Bronco 120v power port not working z2021-11-06_17.53.52
I wonder, though, if these chargers really pull as much as they claim, or whether DeWalt greatly overstated it just to allow a generous margin of safety. 6 amps at 120 volts would be 720 watts. But the output is up to 12 amps at 20 volts, which would be only 240 watts. I know that some loss is to be expected, an of course, the cooling fan needs power, but does this charger really need three times as much power in* as it puts out?
The lesser charger claims it needs 3 amps, which, at 120 volts, would be 360 watts. It outputs up to 8 amps at 20 volts, which would be 160 watts, Not as extreme as the DCB1112, but still, does it really need twice as much power in* as it puts out?
Hey, Seanette — In all your various rearrangement of stuff in the apartment, do you have any memory of seeing something that consists of a plug, and a receptacle, both bright yellow, with three separate wires,, green, white and black, connecting them? Sort of like a very short extension cord, but with three separate wires rather than one cable? I think I either need to find that, or buy the parts and make another, so that I can measure how much current these chargers really draw.
* For any who live in or near Sacramento, farther north, this becomes Howe Avenue.
mpeugeot
He waxed it... I'm telling you, it's obvious now.
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
Put a multimeter on it, or one of those three pronged plug testers. You can check the voltage without load. We all assume you had the Bronco engine running while you tried the outlet right?
Drex
Jake
Yes, I was the only one that wasn't confusing it with the 12V. It is not 400W, it rated at 150W at 110V (per the cover), that is 1.3A. Unless there has been some change in the specs for 2021, ignore those that claim 400W (and 3 plus amps).
Bob Blaylock
Bob
2016 Dodge Dart
Are you sure about that? 150 watts would be so wimpy as to not be worth even existing as a 120V receptacle.
I cannot find anything specific to the 2022 model year, but every reference that I can find to it for 2021 clearly claims that it is 400 watts.
Ford Bronco 120v power port not working 1636250834161
Bob Blaylock
Bob
2016 Dodge Dart
OK, I found one place where it claims that it's only 150 watts. I hope that's wrong. Everywhere else I can find any reference to the receptacle, it either says nothing about how much power, or else it says 400 watts.
Ford Bronco 120v power port not working 1636251369193
