linda_aig
Lux Sponsor (Level 2)
Montgomery
bronco outer banks
AIGMUX launches new product Roof off-road overhead Molle panel, suitable for Ford Bronco 2021-2024 hardtop and soft-surface four-door versions. (Not suitable for two-door version)
New products are newly released, with a 10% discount. Quantity is limited, first come first served.
Product Links: https://www.amazon.com/dp/B0DP6W92H9
Promotion Code: 10YGU8GS
Product details are as follows:
Applicable Models: AIGMUX Off-Road Molle Panel with LED Touch Light is suitable for Ford Bronco 4-Door Hardtop and Softside Versions, Not Suitable for 2-Door Versions.
Storage Space: AIGMUX Roof Molle Panel can store Molle bags, phone/tablet holders, and any other gear you want to take with you on the road. The top of the panel bulges outward, allowing you to store small items such as blankets, bags, and other adventure gear.
Accessories: Molle Panel with Light, Bolt-On Connection, Paper Instruction Manual
Durable Design: AIGMUX Roof Molle Panel is made of aluminum alloy and iron with a micro-textured black powder coating, lightweight design, highlighting the rig's stylish interior styling. Make your adventure safer and more convenient
Join the AIGMUX community to learn about the latest product releases, exclusive promotional discounts and abundant free product opportunities.
Lowcountry Bronco
William
South Carolina Lowcountry
I bet 2 door folks would like this too.
nolimits
23 Badlands
American made? What type and how thick of metal is used for the cross brace? What kind of strength will the cross brace add? Just enough for the molle bracket or help stiffen the chassis too?
AIGMUX
Los Angeles
bronco 2022
Bellime
Keith
2022 Ford Bronco
Does it work with the hardtop installed? Pictures?
linda_aig
linda_aig
Montgomery
bronco outer banks
It does not affect the use of any functions of the original car, and both the soft top and hard top can be used normally. You just need to remove the roof when installing this product.
irishkpo
Kevin
Minnesota
'91 300ZX TT, '23 BRaptor, '24 2dr Yellowstone HLE
Does this turn on and off with the doors or does the lighting only work with the button?
Also since it's -14F outside and I don't want to remove my top to see the connections.... do you know if this fits underneath the roof brace on a Raptor Bronco? If I have to remove that brace to install it and it fits cleanly underneath it even if it uses the same mounting holes than I'm interested. Hopefully there is enough room between the two for my Jtop Bimini to slide between them. I've been looking for a overhead Molle solution that works with the existing brace.
JediMcMuffin
Tommy
2021 Bronco Badlands
Will wait for reviews on this one, but I like how high it is. the integrated lighting is nice. would be nice if it was RGB
linda_aig
linda_aig
Montgomery
bronco outer banks
Hello, our lights only work with buttons, suitable for your Raptor Bronco, I updated the installation instructions, I think you can learn about it first
linda_aig
linda_aig
Montgomery
bronco outer banks
Installation Instructions
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
Is this overhead panel compatible with the JTOPS bimini top? It looks like your cross-bar might interfere with how the JTOPS bimini top connects to the Bronco B-pillar plate.
linda_aig
linda_aig
Montgomery
bronco outer banks
The two can work at the same time without any impact on each other.
JTopsUSA
www.broncosunshades.com
Ram 1500 diesel,
This is Mike with JTops. Looking at the photos I have to respectfully disagree with this comment.
The shade goes under the B pillar bracket and then sits on top of the windshield Chanel. That will create a conflict of the front mount. The shade would be over the top at the windshield and then under at the B Pillar.
If I am wrong please let me know. I just want to make sure the customer does not run into an issue.
Founder
JTopsUSA
