DandyMan985
Louisiana
2024 Bronco OBX
Little present for the ride. ‘24 OBX.
Raceline Ryno 18x9 +18
Nitto Terra Grappler G3 275 70R/18 116T
Before:
Ford Bronco Nitto Terra Grappler G3 Tires + Raceline Ryno Wheels installed IMG_3130
After:
Ford Bronco Nitto Terra Grappler G3 Tires + Raceline Ryno Wheels installed IMG_3135
Ford Bronco Nitto Terra Grappler G3 Tires + Raceline Ryno Wheels installed IMG_3134
Update 12/15:
Only had them for a day, but so far so good. A jump up from 255 to 275 will be felt a little, but they handle well aren’t loud at all. Only a .1 mpg difference so far.
I drive a pebble road once a week from January to June so I won’t know about holding rocks until then.
Wildruby
Canada
Before:
After:
im wondering how you like these tires. One of the only reviews I have seen is buddy said they hold stones like crazy. Also I wonder how good they are in the snow
jdmountford
Jarrid
Meridian Colorado
Ford Bronco Wildtrak '24 & Jeep Gladiator Mojave '21
I'm also curious how you like them! Mine are on order. Going on this week.
DandyMan985
Louisiana
2024 Bronco OBX
Fordified1
Bob
Mid South Texas
I’ve had Terra Grapplers on both a Gladiator and 4wd Excursion. Great tires. I don’t recall noticing they hold rocks any worse than any other aggressive tread tire. And they are quieter than the MT Legend tires I switched to on the Excursion. I wish I had stuck with the Nittos which also wore very well. I only took them off to go from 33’s to 35’s after running over a piece of steel that went through the sidewall.
jdmountford
Jarrid
Meridian Colorado
I had the original Terra Grapplers on a Wrangler and they were good tires. I don't think anything can hold and grab rocks as bad as the Goodyear Territory that the Sasquatch comes with.
Wildruby
Canada
The new ones, G3?
Fordified1
Bob
Mid South Texas
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Jealous of your shadow black painted hardtop!
AZ_Craig
Craig
Mesa, AZ
2024 Ford Bronco Raptor, 2023 Kia EV6 GT
I had the G2 on my 4Runner TRD Pro for about 10K miles before I swapped it out. It was fine but didn't seem to do anything particularly great.
I'm glad to see Nitto finally got a 3PMS rating on one of their tires other than the Exo Grapplier though; that's kept me away for the last few years (and I did run both a Trail Grappler followed by an Exo Grappler on my Jeep around 10 years ago, plus a Nomad Grappler on my Discovery Sport). I felt like the Toyo Open Country 3 (from their sister company) was a much better all around tire for the last few years as the G2 kind of aged on the market.
bruce 1
bruce
pa.
2023 bronco OB 4door 2.7 velocity blue
Before:
After:
Update 12/15:
I have an OB I'm going to get the same tires and a similar wheel do your tires have any poke with that offset.
DandyMan985
Louisiana
2024 Bronco OBX
Yes. About 1.5 - 1.75. I left my non SAS fender flares on, so if I swapped out for SAS flares it may be less noticeable. But I’m good with it. improved the stance a bunch.
The Ryno’s are +18, so if you want less poke you want to find something between +18 and +55.
the MPG hit has been noticeable, but not awful. 2 mpg Less.
