Status
Not open for further replies.
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
Jeep LJ, Ford Ranger, Ford Bronco
Ford Bronco FREE GIFT With ARB Air Locker Purchase! ๐ŸŽ๐Ÿ”’ IG Swipe WIDE-5
Hands down, one of the most important upgrades you can make to your 4x4! Overlanders, Weekend Warriors, and Rock Crawlersโ€”ARB Air Lockers deliver unmatched traction and control for every adventurer.
This offer runs from October 1-31. Don't miss outโ€”visit our website or contact your preferred ARB Authorized Dealer to take advantage today!
What is a locker or locking differential?
Did you know that most 4X4โ€™s are not all truly four-wheel drive? This is because most four-wheel drive vehicles are equipped with open differentials.
An open differential sends power to the tire that has the least traction, and it also differentiates the speed of the tires when turning. This is perfect for on-road use but not so much for off-road use.
When off-road, we encounter obstacles that may cause one or more of our tires to lose traction. When youโ€™re stuck in this bind, you need the tire that has traction to spin in order to get you out of the sticky situation. This type of situation is when a locking differential is needed.
For this reason, many only consider true four-wheel drive vehicles to be those with front and rear locking differentials.
Ford Bronco FREE GIFT With ARB Air Locker Purchase! ๐ŸŽ๐Ÿ”’ ARB-Locker-Switches-1096x480
Selectable Lockers
There are many locker options on the market: electric, Air Locker, spools, limited slips, lunchbox, etc. Air Lockers and electric lockers are selectable lockers, making them the fan favorite.
Remember earlier when I mentioned open differentials being superior on the pavement? Well selectable lockers remain an open differential; but with the switch of a button or pull of cable, this locker will lock completely and send power to both tires. Making selectable lockers the most ideal locking differential for on and off-road driving.
Ford Bronco FREE GIFT With ARB Air Locker Purchase! ๐ŸŽ๐Ÿ”’ airlockerinstall
ARB Air Lockers
ARB Air Lockers are completely selectable giving you the functionality of an open differential on-road but the traction off-road with the press of the button. ARB has a patented timed locking process that allows the locker to lock only in the strongest possible position. This allows an increase in strength of up to 40%. The ARB Air Locker is designed to be the strongest component in the axle assembly.
You may be thinking, why air? Air pressure allows for faster, firmer locker engagement. This allows the ARB Air Locker to be engaged at nearly any speed as long as wheel speed is close to equal from side to side. Many selectable lockers on the market require engagement speeds of less than 5MPH. Air engagement also allows for faster disengagement. Youโ€™ll find that many other brands or factory selectable lockers are quite slow and finicky when disengaging.
Ford Bronco FREE GIFT With ARB Air Locker Purchase! ๐ŸŽ๐Ÿ”’ broncokoh
This year, Air Locker equipped Ford Broncos claimed the Top 3 spots in the 4600 class at the 2023 Ultra4 Every Man Challenge for the second year in a row!
Ford Bronco FREE GIFT With ARB Air Locker Purchase! ๐ŸŽ๐Ÿ”’ 1665445380563
ARB Air Compressors
You have probably heard an off-road guru tell you that a tire deflator is one of the most important pieces of equipment for your four-wheeler. This is because lower air pressure in your tires provides a larger footprint for superior traction as well as a better ride when off-road.
But that poses a problem when trying to get back on the road. You need a way to re-inflate your tires. Sure, you can wait in line to borrow a friend's air compressor. You can drive (who knows how many miles) on deflated tires to the closest gas station. Or you can install an on-board ARB Air Compressor which will allow you to inflate tires, actuate Air Lockers, run air tools, and much more. Making it a critical addition to any four-wheeler.
Buy 1 Air Locker, get a FREE Activation System (#CKSA12)
Buy 2 Air Lockers, get a FREE 12V Air Compressor (#CKMA12)
Contact your preferred ARB dealer to order or visit our website https://arbusa.com/
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
Is there an air locker upgrade available for those of us with 4.46 gears up front?
Ryan at ARB
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
Not if they're factory gears. The front ring gear is welded to the differential.
nolimits
23 Badlands
I have 4.46โ€™s in my Badlands with electric lockers from the factory.
When considering going to 5.38โ€™s I saw these warnings about welded differentials. It seems 3.73โ€™s and any 7-speed manual shift w/o Squatch are welded.
Not saying this a complete list, but seems like a reasonable start point.
https://performanceparts.ford.com/part/M-4209-538
Ford Bronco FREE GIFT With ARB Air Locker Purchase! ๐ŸŽ๐Ÿ”’ IMG_1465
Status
