- Ryan
- Apr 27, 2022
- 26
- 156
- 821
- Auburn, HI
- Website
- arbusa.com
- Jeep LJ, Ford Ranger, Ford Bronco
- Outer Banks
Looking to protect your lowered Bronco from speed bumps at the mall or your lifted Bronco from rocks on the trail? Whatever it may be, rock sliders are a vital piece of protection equipment that every 4X4 needs.
Rock Sliders protect the vulnerable lower door sills from body damage while also providing you with the ability to “slide” over certain obstacles without getting hung up. A quality pair of rock sliders are strong enough to support the entire load of the vehicle upon impact, something a conventional step cannot do.
Allow me to paint the picture for you! Your off-road, front drive side tire is crawling over a large boulder, the tire clears the obstacle but hasn’t made it to the ground just yet. This means the obstacle has made contact with the lower door sill…an exposed lower door sill is now damaged to the point where you are unable to open the door. Or your side step is now so bent that it dented the lower door sill – collateral damage! You won’t believe the number of side steps, both factory and aftermarket, that I have seen on the side of the trail.
OR your trusty frame mounted ARB Rock Sliders saved the day and your able to make it over the obstacle!
ARB’s frame mounted Rock Sliders are 4mm thick, multi folded steel which provide optimum protection and rigidity. The textured Integrit finish accompanied by the stylish silver emblem plate allows it to match the rest of the ARB protection line giving your Bronco the full package look!
Key Features
Part number #4480010
Ford Bronco 2 Door Sliders coming soon!
Key Features
- Vehicle-specific design to suit the Ford Bronco 4-door
- Durable, steel construction for maximum protection
- Slider section manufactured from 4mm laser cut, multi-folded and pulse welded sheet steel
- Finished in Integrit textured black powder coat
- Approximate weight of the sliders: 121lb
- Driver Side Rock Slider
- Passenger Side Rock Slider
