0mm offset vs 20mm offset wheels with Sasquatch package/fenders
BoatMan
Dan
Central Washington
Ford F150
The search is over. I'm going with the Fuel Rebel wheels (Anthracite with Black Ring) for my Carbonized Gray Big Bend Mansquatch. For those of you who have purchased aftermarket wheels, I would like your opinions on no poke vs slight poke. I'm going with a 295/70R18 Nitto Grappler, so the tire is the same height as stock Goodyear Territory, it is about an inch narrower.
I'm sure both will look good, but getting others' opinions is always helpful in making a decision..... Thanks in advance for your thoughts (please include pics if you have any).
CHALK911
SACRAMENTO
07 Ram 2500, 74 Bronco
I think the more the poke the worse it looks. I wouldn't want it outside the flares.
I got a BD SAS and certainly wouldn't want them with any more poke.
The poke will throw more rocks on your doors too.
My opinion is nothing more than the look I like.
It's your ride, look at as many pics as you can find, and go with what makes you happy.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I think 20mm should take you right about to the edge of the flare and 0 should poke past a little.
I feel good at +20 with standard flares when I get around to buying new wheels.
Dez
Geoff
Framingbury, MA
1967 Mustang, 2021 Hyundai Kona, 2021 Ford Bronco
Non SAS truck but these are 17X8 w/ +18mm offset and stock flares. Tires are 285/70/17. I'm sure with SAS flares there would be no poke or at most sidewall poke.
Ford Bronco 0mm offset vs 20mm offset wheels with Sasquatch package/fenders IMG_6399
Ford Bronco 0mm offset vs 20mm offset wheels with Sasquatch package/fenders IMG_6387
Ford Bronco 0mm offset vs 20mm offset wheels with Sasquatch package/fenders IMG_6388
SupremoSombrero
James
West Palm Beach, FL
2013 Mustang Shelby GT500
20mm is the most poke I'd go for. You're also messing up your steering geometry and the springs/shocks have sub-optimal motion ratios.
BOLD Renegade93
Bossier City, LA
2021 Ford Bronco Black Diamond
Ford Bronco 0mm offset vs 20mm offset wheels with Sasquatch package/fenders 084434D8-7B45-4CDA-BB69-94239C820A16
Ford Bronco 0mm offset vs 20mm offset wheels with Sasquatch package/fenders 8C51D67A-9BD2-4C45-86F7-12C5A7895444
Here’s my non-SAS BD with 17x8 and 0 offset wheels. Tires are BFG KO2s in 295/70R17.
Pics are before and after swapping flares to SAS
BoatMan
Dan
Central Washington
Ford F150
Thanks for all your input! 20mm offset it is. Tires and wheels are on order. I'll post pics once it arrives.....
Coach4088
NorCal
Do you any pics of how it turned out? Would love to see it!
BoatMan
Dan
Central Washington
Ford F150
My Bronco just shipped and will be arriving here between 6/15 and 6/21. I will definitely post pics as soon as I take delivery. Also adding Go Rhino boards.....
_ThePhew
Denzel
Atlanta, Georgia
24’ Bronco Big Bend
Do you notice a big difference with 0mm offset? Thinking about doing 0 but seems like may cause a lot of stress.
orion
Jeremy
17' F-250, 17' Explorer
Updates???
