- First Name
- Rick
- Joined
- May 20, 2026
- Threads
- 0
- Messages
- 44
- Reaction score
- 41
- Location
- The ZZ Top State
- Vehicle(s)
- 2026 Bronco
- Your Bronco Model
- Big Bend
26 Big Bend, this would be Awesome! Following.
I would love this projectAs a new sponsor of Bronco 6G, we want to give one of YOU a complete coilover suspension system!
Just follow us on here and comment below!
This is the TeraFlex 3.5" Alpine RT3 Suspension System featuring Alpine IR Short Control Arms with our famous IR (Independent Rotation) Bushings. This suspension system tackles rugged trails or Baja silt beds as well as the daily commute. Engineered to improve the Bronco's off-road suspension while refining on-road ride quality without sacrificing stability.
The system also includes a full set of Falcon 3.3 Series Fast Adjust Coilover Shocks. These Bronco-specific coilovers incorporate an internal hydraulic bump stop that virtually eliminates harsh bottoming when unexpected terrain hits. The Falcon 3.3 Series Coilovers are the finishing touch providing precise control, balanced damping, and confidence both on and off the trail.
Features and Benefits:
Learn More: 2021+ Ford Bronco 3.5" RT3 Suspension System With 3.3 Falcon Fast Adjust Coilover Shocks
- 3.5" lift •Bolt on no welding required
- Direct bolt up Rear upper adjustable IR Control Arms
- Rear lower IR arms using factory brackets
- Innovative IR or Independent Rotation Bushings
- Maintenance free suspension components
- Maximum suspension travel for off-road flex and articulation
- Falcon 3.5" Series 3.3 Fast Adjust Coilover Shocks
- Falcon Coilover Shocks with 4000psi internal Hydraulic Bump Stops
- Forged Front Upper Control arms w/IR bushings
- Industry exclusive quiet, positive, shock mounting point bearings
- Long travel/high clearance rear Lower Spring Carriers
- Vehicle-specific Bronco valving and ride tuning
- UCAs include properly HD Adjustable Ball Joints for precision steering control
- Clears up to 37" tires with minor trimming
Winner will be selected on September 7th, 2026. Must be following the TeraFlex account on Bronco 6G forum and have commented on this thread.
US only. MSRP of $5,899.99.
Learn more:
Also See Our:
Bronco Spacer Lifts & Body Lift by TeraFlex
Bronco Heavy Duty Tie Rods & Steering Rack Support Bushing by TeraFlex
TeraFlex Pneumatic Dual-Rate Sway Bar for Bronco
