How to make my Bronco better offroad?
td11
Tim
Springfeild
2022 Silverado 2500 High Country
Hi folks. I have a stock Bronco First Edition. I finally took it to a trail yesterday and my friends son was also there so we off-roaded together. He has a 1999 Jeep Cherokee XJ, also mostly stock and he was doing way better than me offroad. (Getting up hills I couldn’t, going over logs I couldn’t) He dosent have lockers or solid axles so I was confused. I need to find out how to make my Bronco better or I may just trade it for an XJ. Also does anyone have a good body shop to recommend because my Bronco is a bit beat up from offroad use.
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
Hi folks. I have a stock Bronco First Edition. I finally took it to a trail yesterday and my friends son was also there so we off-roaded together. He has a 1999 Jeep Cherokee XJ, also mostly stock and he was doing way better than me offroad. (Getting up hills I couldn’t, going over logs I couldn’t) He dosent have lockers or solid axles so I was confused. I need to find out how to make my Bronco better or I may just trade it for an XJ. Also does anyone have a good body shop to recommend because my Bronco is very beat up from offroad use.
Ford Bronco How to make my Bronco better offroad? 1660427063166
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
Hate to say it, but if this is real, it is 100% driver.
Ground_zero298
Scs michigan
Just trade it in for a jeep. Then you can post on the jeep forums how your friends Prius is more capable then your jeep.
Or if you want, I’ll take it off your hands sight unseen for $30k cash. Will hop on the jet and be in Springfield when ever you say. Just let me know. I’ll hand you 3 stacks. You give me the keys and title. Problem solved.
RBF 1401
Tricia
Tucson
98 Avalon, 95 Dakota
I'm still trying to figure out how after the first time you take a vehicle off road, it already needs a body shop.🤔
I, too, need pictures to make sense of this.
I've gone "off roading" in a Toyota Avalon with two and a half inches of ground clearance. And while I do have a couple of scratch marks on the undercarriage, I certainly didn't need a body shop.
Did you roll it or something?🤪
RHeinz
Ric
Houston, TX
Sell the First Edition to a collector who will value it and treat it for what it should become, a collector item. Modified collector items, for the most part lose their collector (First Edition) value.
Buy a base Bronco with the proceeds of the First Edition sale, and modify away.
