- Nate
- Jul 14, 2020
- 54
- 2,696
- 5,859
- Sac-a-tomatoes
- Bronco, F150
- Black Diamond
Here we go!
We will start with the outers. Overall the Dorman is much thicker and does require some assembly and comes dry(I will use Moly).
The Dorman comes with a drilled stud for use with castle and a cotter pin. I have mixed feelings on castle nuts, for a max strength item I want more thread contact and a solid stud. I do however like the boot more on the Dorman it is thicker but red.
The inners look the same but definitely different. The Icon in silver and Dorman is black.
You definitely can mix and match like the Dorman outer onto a Icon inner.
Icon is 12mm at the narrowest point
Dorman is a hair more 12mm
Then we have the BIGGEST ISSUE with Dorman heat discoloration at the weakest point! Link to some random site so people don't think I being out of place.
Icon seems to have a better socket ball design and is much tighter.
Now the boots! Dorman is by far the best boots I have seen! THEY ARE HOSS 3.0 SIZE! So much more area to grip and even has a slight ridge inside to help stay on the rack. FYI I would run stock boots with HOSS 2.0 steering(rack better have some upgrades).
Clamps, Dorman provides factory style. I would prefer some screw hose clamps but zero issues with what's provided.
Icons in a bag because I don't like them.
Take away,
Dorman is right their with Icon, both are near identical. Your ultimately looking at the joints and Icon looks like it has a slight edge. The Dorman joints look similar to lower quality tie rods while Icon is more factory. Also is your not a HOSS 3.0 steering rack you don't want to use the Dorman Boots. The boot adapter has a seam and its plastic which will leak. Icon boots are crappy and I am using the factory one currently(going to put those fancy dorman ones on asap).
Take away,
