- Nate
- Jul 14, 2020
- 55
- 2,712
- 5,909
- Sac-a-tomatoes
- Bronco, F150
- Black Diamond
The BroncBuster guy comes across as used car like and a quick buck guy. Being the engineer (I think) that he is, he should know better than armoring tie rods without giving any attention to the rack, which is what you'll "bust" if those rods don't give and break as they're meant to.Didn't watch the whole thing but the portal axle battle is tit for tat!
@tmason10 you forgot to spam the forum?
I absolutely agree with every point you make. Problem is that every engineer has a specialty. I do not think gear design is his based on his presentation above. He is just selling his product. He is right that the helical gears will be significantly quieter. That is because they have a sliding engagement.The BroncBuster guy comes across as used car like and a quick buck guy. Being the engineer (I think) that he is, he should know better than armoring tie rods without giving any attention to the rack, which is what you'll "bust" if those rods don't give and break as they're meant to.
Lots of guys on this forum foolishly have purchased those brackets to potential disastrous results.
If I could afford the 74 Weld portals, would get them tomorrow. Hope to get their rack in a year or so.
Have you seen this video? I'm not an engineer nor know much about gear design and whatnot, it seems that they've spent a lot of time considering (and testing in competition) what works best. I would definitely like their portals plus the HOSS 3 rack.I absolutely agree with every point you make. Problem is that every engineer has a specialty. I do not think gear design is his based on his presentation above. He is just selling his product. He is right that the helical gears will be significantly quieter. That is because they have a sliding engagement.
I am probably weird because I actually like the sound of the spur gears. But it is so much more than that as to why I will be choosing a 4 gear spur design. First and foremost is the bearings inside the portal..
OH he directly mentions weld over and over in this vid.... Even the portals in the H1 were originally spurs... I think they may have changed to helical. Using todays technology Helical gears are not really more expensive to cut than spur gears... the additional cost is when you start adding in a 4th gear and the support bearings. That is done for strength. I also like that I do not have the helical vampire stealing my power.... yes I have that in my transmission from ford..... But like you I would rather have the spur gear transmission as whinny as it is.Haven't watched yet, but I will, I see this as a rebuttal to Quinn's "digs" on IG and YT where he shows portals going 85 MPH with no noise, drives the bronco to show there is no noise, Bronco doing a burnout and all you hear are the tires squealing. He never calls him out specifically but if you listen how he says it you can tell who he is referring to.
I am not an engineer but I do pay attention. years ago I was always trying to save my pennies so one day I could afford a G-Force transmission for my Stang. Why?? Because it used straight cut gears. Those trans would shift the next gear no if's, no ands, no buts, light pressure on the shifter and BANG!! next gear. It made miss shifts a thing of the past. Not to mention you did need the clutch to shift either. These were popular in Nascar cup racing as well. I only make this point because BB harps about being straight cut gears and for me I don't care how noisy they are I care how well it holds up and how well it works.
Plus, Quinn has actually explained why he built the way he built. BB just tries to force his take on you. I don't see BB as much of an engineer, otherwise he would explain his product in more detail.
Yes I have watched.... I also get the impression that he knows what he is talking about. That coming from someone that has a clue (or at least I like to think I do, at least significantly more than most people). When I go to portals I like his design for the stage three rack... It appears to be significantly stronger case while using the HOSS three rack internals with additional support.Have you seen this video? I'm not an engineer nor know much about gear design and whatnot, it seems that they've spent a lot of time considering (and testing in competition) what works best. I would definitely like their portals plus the HOSS 3 rack.
I guess I'd like to hear them in person and know more about the high-speed characteristics, but I've already started putting money aside...
All you have to do is look at the choices he made when lifting his own rig... Sorry to say this but it makes me cringe. It was all about ride height and big tires. NO he did not improve articulation. I would put money on the ride being really firm. has dramatically improved up travel at the cost of droop.Friends don't let friends buy Broncbuster. It still amazes me that people buy his tie rod brackets when they could be buying far superior ICONs for about the same price. 74Weld is currently the only company providing good steering rack enclosures and portals.
You do understand that the portals he is selling are not made in America? Right?I dont care. ‘Merica. As a veteran Im buying broncbuster, every day and twice on sunday. His bushing video really hit home about ONLY BUYING US MADE, not overseas people stealing our jobs the jobs of HARDWORKING americans…..
and thats all i need to know.
Broncbuster ‘Merican Portals….
A
M
E
R
I
C
A
IYKYK
Since you did not see the sarcasm>>>>>>>You do understand that the portals he is selling are not made in America? Right?
You are absolutely correct! I missed that. I can be a little slow at times. The problem is mcinfantry was so convincingly mimicking some of my neighbors... Sounded EXACTLY like them. I bought it....Since you did not see the sarcasm>>>>>>>
BroncoBuster made a video about made in the USA because Rough Country, known for overseas stuff, copied his overpriced bushing for cheap. Guess no one told him those bushings were made in the USA.
Now we have BB who was preaching made in the USA selling, no-no trying to convince people to buy, his portals made in Germany, when Quinn (74Weld) is already making portals made in the USA. Now Quinn has made a BB "style" bushing and pass side housing cheaper than BB, so now BB is mad and he made the above video trying to convince people that Quinn is behind the times on his portals. Problem is BB has not done his homework.
