XL Pro vs Squadron Pro
Baja Designs
San Marcos
At Baja Designs, we get a handful of questions about the lighting packages we sell and how they perform. With these questions popping up frequently we decided it was time to let that cat out of the bag and share some night output shots of two of our commonly compared lights. On paper, the Squadron Pro and XL Pro look to perform similarly but most ask why the price tag says otherwise. While both lights are designed with the top quality CREE LEDs, Thermal Management, and CopperDrive circuit boards the light is also affected by the surrounding components.
In this post, we would like to highlight just how important those surrounding components affect the light's performance. The surrounding components that I am referring to in this product case are the large light housing and the deeper optical reflectors as well as a smaller housing and smaller optical reflectors.
Squadron Pro Spot Single Light
Ford Bronco XL Pro vs Squadron Pro 3Py_7Hh5U65hiKUmcyP4MDNoYI-e_85Q7QK21KXUuPokT7vOuI
Ford Bronco XL Pro vs Squadron Pro PV4IwEVj3LT-aXhxH-5zy_uJW-l1enPydKI6anrBgh2LVAr-X0
Squadron Pro Specs
Amperage Rating (A)3
Average Rated Life (hr.)49,930
Beam PatternSpot
Bezel MaterialBillet Machined Aluminum
Brightness (Lumens)4095
DescriptionSpot; Clear
Housing ColorBlack
Housing MaterialHard Anodized and Powder Coated Cast Aluminum
Lens ColorClear
Lens MaterialHardcoated Polycarbonate
Light Quantity1
Lighting ModesBeam
Lighting Quantity4
Lighting TechnologyCree LED (2 Types)
Lighting TypeForward Projecting
Mounting Hardware IncludedYes
Mounting Hardware MaterialStainless Steel
Overvoltage ProtectionBuilt-In
Product TypeSquadron Pro LED Light Pod
Wattage (W)41.400
XL Pro Spot Single Light
Ford Bronco XL Pro vs Squadron Pro PH3X1VkTQPtQv-tdCqcXC7EPzLqdCLx5wCeNua2P4dmyM4jHmw
Ford Bronco XL Pro vs Squadron Pro hlwTq5eIkLPbuCTGHjB_NHl78Sk9nVsjv98vDfKIUOqiRgxLBY
XL Pro Specs
Beam PatternSpot
Housing ColorBlack
Lens ColorClear
Light Quantity1
Lighting ModesHigh Beam/Dimming Feature (20%)
Lighting Quantity4
Lighting TechnologyCree XP-L LED
Product TypeXL Pro LED Light Pod
Universal or SpecificUniversal
Wattage (W)41.400
So in conclusion, does size really matter? Yes, it does. If your goal is to be able to get more distance the larger XL series reflectors will increase the lights' travel distances over the smaller Squadron reflectors. Both of these packages have great performance for what they bring to the table. Squadron Pros work great if you are looking for a more low-profile light that will pack a punch. The Squadron Pro will give you more near-field lighting but If you are looking to get more distance the XL Pro will provide that extra boost while off-roading. Want to see us compare other models or other lights? Feel free to tell us down below. Interested in some lights ? Shoot me a PM
