Ninjak
Miami
Interesting. I wonder if its the change to the charger to holder double-decker style that made the difference? Did the front not fit into that section now? I used the CF in my BRaptor to finish off the CF package that came with. I had to maneuver the front to get it to sit correctly. I do have a 24, though.
JiuJitsuJoe
Joe
2025 Bronco Badlands⚒
The front fit okay, but the rear section on the 2025 Bronco center console seems just a little taller making the insert not sit flush. If they come out with a 2025 compatible version I’d test it out.
Nc211
Nc211
Washington DC
Since the window switch cover piece is causing it to hit and not seat? I didn't use that piece on mine because it was raised too high for me. Wondering if you tried putting on the center piece before the window switch cover, if it would allow it to sit flat? Or is there just no way it'll work on the 2025?
Nc211
Nc211
Washington DC
I took a gamble and tried installing it on my 2025 Bronco.
Unfortunately, the center console piece was not compatible and that was the last piece I needed to install 🤷🏻‍♂️😆. If the center console piece would’ve fit, I would have kept them.
I was at the dealership yesterday, looked at a 2025 in the showroom and noticed the redesigned phone charging area. I think that is likely the problem for fitment as well unfortunately. Sorry about that!
Anyone buying these trim pieces, lesson learned for the 2025+ model years. The 21-24’s won’t fit on the center console. Hopefully they’ll make a revised version that will!
michelle227
michelle
North Texas/South Canada
Badlands 2dr 7spd/ Mercury Grand Marquis/ Jaguar X-Type/ Fiat Spider
I really thought I would hate it before I opened this thread, but I don't. However, I think it only works with the tan/brown of your interior. It would probably look really out of place on the other interiors.
They should go back and make the Filson Edition with real wood interior pieces and that baseball glove seat leather we all wanted...
Sometimes you have to see it to learn the mental image was 'off.'
My F-Type was black metallic with brown leather seats (and cream stitching). I didn't think black and brown would work. But, seeing it in person, it did...
I could see this working with blues and greens really well if other shades of wood coloring were available...
Cooperhawk
20 miles south of the Twin Cities
2023 Bronco Outer Banks
So I got the kit and it looks great, but, the two sided tape will absolutely not stick. I've tried swabbing the area with alcohol wipes and that didn't help. I took a heat gun and heated it all up. No use. I love how they look but I guess I'll have to replace all the two sided tape on my own.
JiuJitsuJoe
Joe
No worries🤙🏽! It was worth the shot. The vendor refunded.
If they come out with a 2025 update, I’ll pick them up.
Nc211
Nc211
Washington DC
If you have some isopropyl alcohol, empty spray bottle and a microfiber rag, that should clean the surface up of all greases / oils perfectly. I sprayed mine down liberally and wiped it with a microfiber towel. The trim pieces stuck on very well after that. Not sure a "wipe" would be good enough to really clean the surfaces up.
Cooperhawk
Did you use heat?
Cooperhawk
I took your advice about alcohol and micro fiber rags. That worked but what really helped was when I hit it with my heat gun just before I pressed them on. If one didn't adhere all the way I gave it some more heat and presto, it held. Thanks.
Nc211
Nc211
Washington DC
Cooperhawk
We were having a heat wave here in Minnesnowda. It was a balmy 41 degrees. It's 14 today.
Mirage
Huntsville, Alabama
'23 2Dr BL SAS Green/White, '24 2Dr HEL Yellowstone
Agreed! Those would look awesome in my wife's Heritage Limited, but not so much in my Badlands, unless I could find a different color dash/armrest pads? Part of me wishes I had the brown HEL seats too. I believe that would look better with the green?
HalfmuleFarmer
Thomas
2025 Badlands
Ford Bronco Wood trim inserts installed IMG_3337
But do they make exterior panels?!
Squatch
I wonder if it would look good in the new Filson.
