South Jersey
2002 Olds Bravada, 97 Rav4, 2024 2D BD 2.3L auto
Ninjak
Miami
That was a brilliant way to install it. Nice job.
billyum
William
Winder, GA
2024 Ford Bronco
Did you hook this up to work with an ipad? And is there a way to use this with 2 channels? Like let’s say you use the front camera on the ipad and a rear camera on the rear view mirror cam
11811
South Jersey
From what I can tell you cannot watch 2 cameras on different devices simultaneously.
In my photo, I was live streaming the camera to my Ipad via the mirror's wifi connection using the Wolfbox app. In that mode you can see the entire camera image on the Ipad and change views using the the app, not the mirror settings.
D-R0CK
Las Vegas, NV
2022 Bronco Black Diamond
Just installed my tri-pro camera where the adaptive cruise control LiDAR would be if I had one.
https://wolfbox.com/products/wolfbox-g900tripro-bumper-version-3-channel-rearview-mirror
Below are some pictures of the installation and some views to compare how it helps with the blind spot in front of my Bronco. I can now see objects 18" in front of me!
Nice! I mounted mine on the trim under the grill, but this may be a better solution. I worry about getting mud and other stuff caught in behind the faux sensor plate though?
11811
South Jersey
As it is, the top of the cover is wide open so I expect mud gets in there already.
If one goes mudding, I guess they can pop off the cover beforehand. It's just 2 snaps holding it on.
Ford Bronco Wolfbox TriPro Bumper Camera install (in adaptive cruise control sensor location) IMG_3270
11811
South Jersey
For anyone attempting this, I did have to carve out the side of the cover a bit larger to be able to slide the cover past the camera.
The biggest challenge is getting the camera to line up with the hole for the view you want. My hole is 3/4" diameter but I probably should have gone 7/8" or 1" to avoid the peephole look on the camera.
Ford Bronco Wolfbox TriPro Bumper Camera install (in adaptive cruise control sensor location) enlarged cut out
Hole egged out to remove peep hole look
Ford Bronco Wolfbox TriPro Bumper Camera install (in adaptive cruise control sensor location) measurement
11811
South Jersey
Bumper camera view
Ford Bronco Wolfbox TriPro Bumper Camera install (in adaptive cruise control sensor location) 2025_04_10_110415_00_I.JPG
Ford Bronco Wolfbox TriPro Bumper Camera install (in adaptive cruise control sensor location) front vi
11811
South Jersey
Tried my camera setup out in the rain
Front camera with polarizing filter
Ford Bronco Wolfbox TriPro Bumper Camera install (in adaptive cruise control sensor location) 2025_04_11_170909_00_F.JPG
Bumper camera
Ford Bronco Wolfbox TriPro Bumper Camera install (in adaptive cruise control sensor location) 2025_04_11_170909_00_I.JPG
Wolfin
Marc
Maryland
Just got this exact same camera system in, best buy got the dash cam wired up and have a 2nd date set for them to run the cameras on the front bumper and rear bumpers. This is definitely I good thing to show them as to where id want to put the front bumper cam.
Blksn955.o
Greg
Wentzville, MO
Awesome idea, I have my wolfbox camera attached to winch angled down and I am always worried about wind/how far out front it is. Will be looking at this option for sure as it resolves the wind/debris and protect the camera a little.
Digital_Synapse
2015 Mustang GT, 2022 Bronco, 2020 Explorer
kevin.gt
Kevin
Canton, GA
How did you route the power and front camera? I’m struggling to push them both up into the windshield header trim. If you loosened/removed the trim, do you remember what size bronco bolt is holding the visor clip?
