Wolfbox: Knowledge on Hardwire Kit and Installation [Part 2]
WolfBox
Florent
LA
2021 2dr Bronco
Hello,
We’re back with Part 2 of our series on hardwire kit and installation! In this post, we’ll dive deeper into the topic. If you’ve already read Part 1, you’re well on your way to mastering the basics—now it’s time to build on that knowledge.
Make sure to read through this guide carefully, as it’s packed with valuable insights to help you achieve a smooth and safe installation.
Ford Bronco Wolfbox: Knowledge on Hardwire Kit and Installation [Part 2] hardwire kit1
Ford Bronco Wolfbox: Knowledge on Hardwire Kit and Installation [Part 2] hardwire kit2
Ford Bronco Wolfbox: Knowledge on Hardwire Kit and Installation [Part 2] hardwire kit3
Ford Bronco Wolfbox: Knowledge on Hardwire Kit and Installation [Part 2] hardwire kit4
As always, stay tuned for Part 3, where we’ll continue sharing more advanced tips and tricks to help you make the most of your Wolfbox setup!
Wolfbox G900 Tripro
Wolfbox Hardwire Kit
Happy reading,
The Wolfbox Team
Draughon
Daylon
Dallas
BMW 4-Series
I've got a weird issue with my TriPro bumper install... have it hardwired to the fuse taps and every so often, the start stop completely disables the screen and the only way to turn it back on is to cycle the engine completely on / off.
Also when I installed it, I had parking mode, but I lost my side mirror controls, so reversed the fuse tap on the ACC (flipped it over) and got the mirrors back, but lost parking mode and now I have this intermittent start/stop issue.
Just a weird electrical gremlin.
calbare
Jose
Napa, CA
2025 Ford Bronco Heritage
You might want to try the Wolfbox OBD hardwire kit. A lot simpler to setup/use and prob not have electrical gremlins.
WolfBox
WolfBox
Florent
LA
2021 2dr Bronco
I think you should check the fuse taps and change to other ones, sir. There are some reivew threads on the forum that you may find helpful.
