Fishwrinkle
12 GC overland 5.7, 18 GC srt 6.4
rfiorillo
Ralph
Subaru
I was thinking of trying this no drilling and it looks like the closes to the factory wireless charger
Maxzina Fit 2021 2022 2023 Ford Bronco Automatic Center Control Wireless Charger Charging Pad for 2023 Bronco Accessories 2/4 Door https://a.co/d/1dPUH1j
cynicalrider
First gen taco
nice hack. i value that space for other random items and a phone taking it up serves no purpose to me. also i like to be able to see my phone as i drive while using carplay as it doesn't let you perform all fuctions off the acm. this is my solution https://coursemotorsports.com/produ...mount-ford-bronco-2021?variant=44623348597042
Any chance you could please measure the ball on that? That would be an awesome solution for me to use my existing quad lock setup on their ball.
EDIT - NVM so their ball is 17MM, my existing ball is 20MM which i didn't realize I could disassemble. So i bought their mount, the 1" ball, and a quad lock 1" ball to use with a short RAM arm. I would have saved myself some money if I didn't rush but whatever, I am going to try this setup with the RAM mount, and worse comes to worse if I want to eliminate the sue of the RAM arm I can just spend another $25 on the 20MM ball Course sells too.
vluft
TN
2023 2DR
I 3d printed one for the magsafe puck. holds the phone well but the "This USB device is not supported please remove" nag on every start is a bit annoying (still charges fine though).
Ford Bronco Wireless charger DIY IMG_1164
Ford Bronco Wireless charger DIY IMG_0079
Ford Bronco Wireless charger DIY IMG_0078
Min_Ahn
Min_Ahn
Min
Denver, CO
2019 Ford Mustang, 2023 Ford Bronco
Won't work unless you have the cutout in the compartment ("Optional models with Lux Package come with wireless charging pads.")
hokiejerm
Jeremy
Apex, NC
2023 Cactus Gray Badlands 4dr
Did you install with the wireless charging magsafe head, and do you have a pic?
Looks like a great option - says it comes with a 12v cigarette lighter adapter, but assuming the cable is usb.
Fishwrinkle
Yes I used their head and the cable that comes with it is usb to c. I’ll try to get a pic but they have a pic on the site
hokiejerm
Jeremy
Apex, NC
Thanks. Pics on the site look good just none with the wire run from the head to the usb port. Mainly wanted to confirm the provided cable is sufficient so thank you!
Jeremy
Fishwrinkle
yeah, i used a longer cord than the one they sent. due to charging other usb-c implements when needed.
JRW5574
Jason
Charlottesville, VA
2016 F150
After having to forgo the Lux pkg, I felt quite disappointed about losing the wireless phone charger in the center console. Initially, my plan was to install a magsafe charger, but I struggled to find an OEM-looking solution. After days of searching the internet, I eventually stumbled upon a fantastic alternative from Boost Auto that closely resembled an OEM product, and I couldn't be happier with the outcome!
The installation process turned out to be relatively straightforward since they provided all the necessary hardware. The most challenging part was probably removing the horizontal panel between the center console and the AC control. Fortunately, their excellent Youtube installation video proved to be incredibly helpful.
Now, I can charge both Android and Apple phones without any issues, and the rubber material securely holds the phone in place. I'm confident that even during rough rock crawling, the phone will stay firmly fixed.
How long have you had this installed? Anything you're unhappy with? Thank you.
Min_Ahn
Min_Ahn
Min
Denver, CO
For about a week now. No complaints but I keep forgetting to take the phone out of the car now lol
Delight
Delight
Cincinnati
Sequoia
I've used this same one in my BB for over a year now. Works fine...sometimes have to wiggle the phone (iPhone 14 max) a bit to get it set properly. Only downside is the small visible power cord that is plugged into the port.
Ibuprofen3293
Tom
Detroit
22MY Badlands
Route the cable to an adapter in the 12V outlet in the center console and it should charge faster & you won't get that pop up. I had to use a USB-C extension cable because the magsafe cords are too short.
