Windshield washer reservoir capacity
Climber_Diver
Rick
Escape
I’m only getting about a half dozen window washes out of my Windshield washer reservoir. I can’t find any specs on the capacity and it’s pretty well hidden in the fender. It just seems very limited.
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
I first ran low around 3k miles. It fit another whole gallon, even with whatever was still in there.
GToddC5
Todd
South Jersey
www.bronco6g.com
You have a leak!
Climber_Diver
Climber_Diver
Rick
Escape
Climber_Diver
Climber_Diver
Rick
Escape
GToddC5
Todd
South Jersey
www.bronco6g.com
Tarheel_Wes
Wesley
FJ
I have the same questions.
Is this full? Empty? I can't see a line.....
no clue.
Ford Bronco Windshield washer reservoir capacity IMG_3135
Ford Bronco Windshield washer reservoir capacity tempImageU1F7F6
BWarned
Brad
Fort Wayne
21 Wildtrack
I have the same problem with the added fun of no fluid going to the rear wiper. I haven’t taken it in to get checked yet but man that big pop up about low washer fluid every time I start gets awfully annoying
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Strange.
I was psyched when a full gallon fit. It always annoyed me on all my VWs when a fraction of the bottle had to get stashed for next time. Liters? Ha!
Sounds like some sort of pump issue?
PSUTE
Western Maryland
Sierra
There’s no evidence of a leak. Nothing on my garage floor.
You have a leak!
See what happens if you activate it in the garage, pump may be dumping when it's on?
Reason I thought of this is that the fuel pump went out on my Sierra, and leaked when it was on. Hoped it was a cheap fuel line but nope. ***sigh***
Climber_Diver
Climber_Diver
Rick
Escape
Good idea, but still not leaking…
Bt_ostate
Oklahoma/Colorado
2021 Ranger Tremor 2021 Bronco 4-Door FE
Owners manual just says fill as needed, does not provide a capacity. 😞
DefNotBuddyLee
Austin
Mustang / Jeep / F150
I guess it depends on how long you run the washer for you half dozen times.
Barring that, you have already troubleshooted a leak, so that leaves intermittent pump failure (which I assume you hear the pump running, just no fluid coming out), or other reservoir issue (maybe the bottom is filled with sand or jello). When you run out of fluid, how much fluid does it take to refill?
VelocityBrew
Minnesota North Metro
22 Badlands, 20 Passport, 16 1190 Adventure
2300 miles in a Minnesota winter, got a whole gallon into it. Worst fucking filler neck design ever.
