- First Name
- Bri
- Joined
- Feb 27, 2021
- Threads
- 18
- Messages
- 206
- Reaction score
- 197
- Location
- California
- Vehicle(s)
- An old EcoDriver
- Your Bronco Model
- Big Bend
- Thread starter
- #1
Hi,
After having my Windshield replaced I noticed that the windshield wiper sprayer isn't working. I thought it may be clogged but it looks like the fluid reservoir is empty...so I added some fluid (I didn't have much, only about a quart but good enough for a test). All good until I started the ignition and tried to spray wiper fluid - it immediately all leaked out! It came out along the body, dropping on the ground. This is a view just back of the right front tire - the arrow points to where the drips came from (it was a stream while it lasted).
Looking under the hood, the area close to under the windshield is wet with wiper fluid:
So: I suspect that, when the windshield was replaced that the wiper fluid line like wasn't hooked up correctly. Before I go back to the dealership I'd like to see if I can find the leak and fix it myself (the first dealer appt is in two weeks). I will need to remove the plastic piece at the base of the windshield that houses the windshield wipers- the long piece:
Does anybody know how to remove this housing? And how to remove the wiper arms? I'm not a mechanic but can follow a recipe. Anybody removed this before?
Thanks.
Thanks.
