Window Sticker Build date ???
WildTrak23
James
SW Missouri
2016 Ford F150 FX4 Crew Cab Flame Blue
Sorry to ask this, And I did a search on here , But I know you all know the answer. Where on your Window Sticker is the Build/Birth date of your Bronco?? Is it the date on the bottom of the page? Because the door only shows month and year. Thanks for any and all information.
Ducati1098
The actual build date isn’t listed on the window sticker.
You can use the blend date which is typically a few days before the build date though
Blend date is the last 6 digits on this picture. So it would be 4/26/22
Ford Bronco Window Sticker Build date ??? 140CED94-D3B3-47D0-A227-3E539ECE8BAC
WildTrak23
WildTrak23
James
SW Missouri
Thanks I had noticed on mine there was a date at the bottom right in a white box by its self. I was wondering what that on was?
Bushwhacker
Todd
Georgia
GMC Sierra Z71
Ducati1098
I’m not sure about that. I don’t see a date in a white box on mine.
Rspayde
North Ga
2022 C/O Black Diamond
I am pretty sure the date you are referring to just updates to the current day every time you open the window sticker. Or it is just the same blend date info repeated.
DrewMackin
Drew
Dripping Springs, TX
23 Tesla Model 3, 23 Bronco Heritage
Sometimes the blend date disappears! My window sticker updated after my Bronco was built, but not shipped. After the update it no longer had the blend date on it. The whole top portion of the sticker changed but didn't seem to cause any issues.
helifino16
Ron
Mount Sinai, NY (Long Island)
If you - like most people do - look obsessively at your Window Sticker, you'll see that date change almost weekly, if not more often. The consensus is that date is pretty much meaningless. If hidden fields are actually changing on the Sticker, the info hidden is probably not pertinent to you as well. What you see is all that you will get out of the Sticker, there is no secret meaning behind anything that may change on it.
WildTrak23
WildTrak23
James
SW Missouri
As always Thank You to Everyone for all input. The above treads were very cool when you look into them. Very informative. I was mostly curious about the sticker that came with it when I picked it up. The bottom date in the white box shares my daughters birthdate. I was thinking it was cool if it was a born on date that matched hers. LOL
