- John
- Mar 22, 2021
- 41
- 2,320
- 2,937
- Charleston SC
- 2021 Bronco 4dr OBX MIC 2.7 Rear Locker A51 Roast
- Outer Banks
Others have this issue, and its easily repaired! My original post:
"The auto window-down feature where the window goes down just enough so I can open the door has stopped working on the driver's side. All the other ones work. This means I have to put the window down before I get out and go in the passenger side to put the window up if I leave the car locked. Anyone else have this issue?"
It turns out this is a common problem, and is easily repaired. @Ironmomof3 posted a solution, which I tried in a rest area in Georgia on my way from Jacksonville to Charleston. You can see the video below, but essentially I turned on the key, put the window down and held the switch for 5 extra seconds. Then, I put the window up and continued holding the window up button another 5 seconds. That reset the window control and all is well!
OBX
OBX
