Will it fit? Wheel question
peterh
ny
jeep wrangler jlu 2018
Guys-
Not knowledgeable about cars so hoping someone can provide an answer to this question.
I found an older wheel that I am thinking of trying and not sure what else I need to know in order to confirm it will fit - specs are:
17 x 7.5
Offset +31
Bolt pattern: 6-5.5 (also listed on Ebay as 6-139.7)
I have a Badlands so OEM wheel is 17x8 and tires are 285-70-17
Will it fit or do I need to know more?
Thanks, appreciate any help
peterh
peterh
ny
Thank you sir, seems like they will work, now just wondering about whether I will need to remove the crash bars
Badsquatchman
Brent
Maryland
motorcycle & 93 Z28
Depends on tires- I think you stock will be just fine
peterh
peterh
ny
thanks yes gonna keep the same stock tire and when they need to be replaced will use the same size
peterh
peterh
ny
Thank you for this explanation - so if I found a wheel with a 106.1 you think they can be fitted if all other specs are in line? I am going to reach out to a wheel company but would love to know your thoughts on that given you said you can sometimes go with a larger bore using an adapter thanks
GI_Jo_Nathan
Jonathan
Yes.
