Will Badlands wheels fit on a Base?
Rossel
TriCities, WA
Ford Edge, C8 Corvette, Road King
I found some Badlands wheels (5) from a local person at a very good price. Any idea if they will fit on my ordered Base and what size tire can I install without rubbing problems. Thanks
r21free
bob
michigan
2021 bronco badlands
yes and 33 are the tallest ...
BoostedBronco
Southeast Georgia
4x4
ievolve
Anthony
ID - USA
Tesla Model 3
My base with Badlands wheels and tires. No issues
Were you able to transfer the TPMS from your base wheels over to the badland wheels, or did you have to buy new ones? I've heard mixed reports on that..
armymp71
Rick
Glen Carbon, IL
Audi q3
The bronco wheels I bought had them so I did not transfer.
FerkinBlonco
AK
2008 KLR 650, 2022 Bronco Base (2dr/7mt/CO)
Did you re-use the lugs from your steelies to mount, or did the BL wheels come with 'em? I'll hopefully be doing this soon too; will be good to know if the BL wheels require different shaped lugs. Thanks!
armymp71
Rick
Glen Carbon, IL
Audi q3
I got the original lugs with the BL wheels. I also thought about painting the steelies and going to bigger tires, but these rims were cheap and easy, really changes the look of a base! Good luck
geronika
OKC
53 Ford Pickup
Make sure you get the Badlands badge to go with it. 🤣
Rossel
Rossel
TriCities, WA
Got my Ford Bronco Base and had Ford Quicklane add BFG KO2 to the Badland wheels. They removed the TPMS from the steel rims, put them on the Badland wheels and used the original lug nuts from the steel rims. I have not adjusted the speedometer yet so at 65 mph per Google maps I am going 70 mph.
Ford Bronco Will Badlands wheels fit on a Base? Bronco Bronco
FerkinBlonco
AK
Thanks! Good to know I don’t have to stress about lugs :) I’ll have to figure out all the Forscan stuff now to adjust tire size. Woo!
Will take a pic of my Baselands once I get the things mounted 🤙
Viper32
Chesnee SC
2022 Bronco and Ford Raptor
Lugs will work from your steelies. All use the same lugs on the Bronco.
frankk
Frank
Lotus Elise
Before and after pics, please 😀
