Will these wheels fit 2023 Base 4 door?
Andy
2023 Bronco Base
Will these wheels fit on my Bronco without lift kit
VISION-WARRIOR 17 X8.5 6-139.70 .25
Tires 285 R70/17
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Depends on the center bore, which you didn't list. Bronco's center bore is 93.1, so the wheel's center bore needs to be 93.1 or larger.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Tires 285 R70/17
The center bore on the Warrior wheel is 106.2 so you will be good.
Andy
2023 Bronco Base
How do I find out what the center bore is
bniknar
Bri
An old EcoDriver
Discount Tire
Arizona, USA
discountti.re
All Things FORD
@Discount Tire Will these fit on my non-SAS big bend? I don't have a lift so I want to ensure there isn't any rubbing:
Vision Warrior, 18x8.5 +18 offset: https://www.americastire.com/buy-wheels/vision-warrior/p/72332
Tires 275 /65 R18 https://www.americastire.com/buy-tires/rocky-mountain-all-terrain/p/120819
The offset of the wheel will create a bit of a poke. The tire height will be a bit higher than the OE tire. You should be ok, but you will most likely need to remove the crash bars.
bniknar
Bri
An old EcoDriver
Thanks. There's another pair I'm looking at:
Vision Warrior 375 17x8.5 +25 offset
https://www.americastire.com/buy-wheels/vision-warrior/p/72320
Tire size 265 /70 R17 115T SL BSW
https://www.americastire.com/buy-tires/rocky-mountain-all-terrain/p/120816
Only issue I can think of here: the OEM tire is slightly larger - Bridgestone Dueler A/T 255/75R17. Is this difference significant?
