Will a 0mm offset be too much poke?
blackdiamondog
Jack
2019 Dodge Ram 3500
I’m weighing options for some wheels to get when my bronco arrives. I’ve come across a great deal on some but it has a 0mm offset. I plan on getting the 2 inch rough country lift thrown on with some 33s. Anyone know if 0mm will cause rub or throw too much rocks with the lift and 33s?
the blue potato
Mr. Gone
East Coast
66 Ford F100
Would get better responses if you asked this under wheels/tires area. Tons and tons of info there to your question.
broadicustomworks
Hanging Rock, North Carolina
Ford Bronco Will a 0mm offset be too much poke? B9B89C92-5EE1-47F9-B1CE-C6735370AAE4
0 offset ICON’s with the stock Sasquatch tires, Sasquatch package.
Yes there are rock chips.
too much poke?
It’s a subjective question.
For me, no.
For some others, yes.
For some others, not enough.
You can gauge your desired level by this pic.
blackdiamondog
blackdiamondog
Jack
2019 Dodge Ram 3500
too much poke?
For me, no.
thanks for the photo, that gives me a pretty good idea in terms of poke. do you have any rubbing on sharp turns?
Drex
Jake
There is no way to know with the information you have given. The width would be needed for someone to calculate the edge positions.
PWillette
Parrie
Maine
Keep in mind the picture above is with SAS flares. Zero offset will put the tires beyond the standard BD flares.
blackdiamondog
blackdiamondog
Jack
2019 Dodge Ram 3500
8.5
blackdiamondog
blackdiamondog
Jack
2019 Dodge Ram 3500
yes. i think i was going to order some of those from the factory and throw them on even if i don’t get different wheels. i’ve seen too many threads about rock chips for me to want to keep the non squatch fenders
broadicustomworks
Zero rubbing. With the 35's.
If I went 37's, they technically would fit. but would slightly rub at full lock, and of course, compromise articulation room.
blackdiamondog
blackdiamondog
Jack
2019 Dodge Ram 3500
about 1.2 inches further out than a Sasquatch wheel, With 33's that would fit on an 8.5" wheel, I don't believe you would have rubbing issues.
thanks for the measurements. i think that pretty much seals the deal on my wheel choice.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
BD wheels are 7.5-inches wide with +55 offset. If you go with 17x8.5 wheels with 0 offset, the lip of the new wheels are going to sit just shy of 2-3/4 inches further outwards. As long as you do not go to a wide 33,. you should be in good shape.
