nabronco21
Nick
Pennsylvania
2021 ford bronco/2008 ford ranger
Money Pit - LOL.
Just as you think there's not ONE more thing you need, someone posts something like this:
They just 'finish the look'.
I recommend not purchasing these caps as they will essentially weld themselves to the valve stem and you will not be able to remove them. Maybe anti seize will work but not too sure.
emkayw
mike
southern california
ford fusion
I have these and similar long-stemmed ones. Funny thing is, the long stemmed ones faded to the point that they nearly match my bronze wheels. Never had a problem removing either set from the valve stems, even in direct SoCal summer sun.
Krokodokolo
Toyota Avalon for now
I havent even bought one yet and the fact that they are such money pits is one of the reasons I want one. :crackup:
nabronco21
Nick
Pennsylvania
Mine did fade to bronze as well. Perhaps it was the salt on the roads in my area that caused the issue.
GroovyGeek
Boyan
'23 Bronco BD
You are either married to an angel or to an indifferent monster who doesn't give a damn. Or, more likely, she spends more on shoes than you do on the WT so she minda her own business so as not to rock the boat.
desibull
Mahesh
Chandler, AZ
BMW 335i
I am so jealous of your lack of self-control!!! Your rig looks amazing! At least we share the same color!
Have you seen a marked difference with the intercooler install? I have been reading about intercoolers but because it is a big ticket item (both the part and the install) just want more input.
Well done with your rig!!
Captkrunch
Captkrunch
Sam
Fresno CA
23 Bronco WildTrak
Hahah, you’re welcome
Badass rig đź’Ş love it!!!
I would also love to see what you did with the CVF cat back to gain more ground clearance.
Well....
I first attempted to utilize a metalClock exhuast guard and modify that.... Didnt work, and i gave up! so i cut it off at the AXLE
So im still trying to figure it out....
Ford Bronco WildTrak 2DR Money Pit IMG_0573
Captkrunch
Captkrunch
Sam
Fresno CA
23 Bronco WildTrak
Haha she is more distracted with the amount i spend on Airplanes!
Captkrunch
Captkrunch
Sam
Fresno CA
23 Bronco WildTrak
A Major difference in Cooling with the H/C Pipes, and intercooler.... About 20 degrees from what i observed with my procal device! @MWLD has a very informative video if you want to check that out!
Captkrunch
Captkrunch
Sam
Fresno CA
23 Bronco WildTrak
Update: Checked the stock CV Axles to see some leaking, ford wont cover it due to modifications (haha) decided to just pull them out...
Ford Bronco WildTrak 2DR Money Pit IMG_0531
and upgrade to RCV axles
Ford Bronco WildTrak 2DR Money Pit IMG_0582
Gtrekker
Gary
Nice build, and a Top Tier color... For the Win!!!
Team 2 Door = Purpose Built and Bad Ass!!!
Captkrunch
Captkrunch
Sam
Fresno CA
23 Bronco WildTrak
Finished the install and took it out for a test spin, nothing broke! So we are good to go!
Ford Bronco WildTrak 2DR Money Pit IMG_7450
Ford Bronco WildTrak 2DR Money Pit IMG_0604
Ford Bronco WildTrak 2DR Money Pit IMG_0603
