Wildpeak A4Ws on non-Squatch Big Bend?
Flc
Denver
Trying to decide between 285/75/17, 285/70/17 and 275/75/17. Looking for the biggest, baddest tires that I can pull off without doing a lift or removing the crash bars.
Daily driver but will also be doing trails, probably up to 4s with the ocassional 5 if I add a rear locker.
Thoughts on the tires?
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
285/70r17s should be the “True 33s”. Those for sure will fit without mods.
Anything bigger may start to rub, mostly due to the wheel offset
  • Like
Reactions: Flc
dgorsett
colorado
F250, Mustang, Explorer
The thought of a 275/75x17 interested me, I went to the Falken website, no listing for that size :( Where have you seen it?
Flc
Denver
Ah sorry, that last one wasn't Falken.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
I haven't been off road with it yet, but the Falken A/T4W has been a great tire for me so far. Smooth, quiet and does well in wet. Worth a look.
Flc
Denver
Biggest complaint I've heard with the A/T4 compared to the 3 is that they're much heavier, worse gas mileage, etc. Thoughts on that?
Discount Tire
Arizona, USA
discountti.re
All Things FORD
They are heavier, and noticed a bit stiffer ride, but not enough to make me regret the decision. I have not put pen to paper on fuel economy as of yet, but the decrease is negligible IMHO.
Flc
Denver
Appreciate the perspective. Going to buy the new wheels from Discount Tires as a result!
Discount Tire
Arizona, USA
discountti.re
All Things FORD
It's our pleasure! We will be happy to assist you with your order. Hope you don't mind a DM being sent your way.
hemiblas
Roger
Aurora, Co
2023 base SAS Bronco, 2018 Rubi JL and JLU
Keep in mind heavier generally also means tougher....You might lose .1 miles per gallon, but these turbo engines don't seem to care much about a little extra weight, so the power loss will be negligible. To me the mileage lost is piece of mind that you won't get stuck out on a trail or have your tire fail on the highway after a trail ride. I had that happen to me.
I also like the 285/70/17 option. It is a really standard size and most peoples goto for a 33" tire.
zo3
2023 OuterBanks
@jdq024 Have you had a chance to get those out on the trail yet? I'm thinking about doing AT4Ws (285/70/18) on my non-sas OBX, which would be about the same size as what you're running. I didn't want to do a lift or remove the crash bars and only do some light off roading so interested to hear your experiences !
