why? Remote Features Disabling
sniffHound
W
Mississippi
Ford Bronco
Why are my remote features disabling? happen once or twice when I didn’t drive it for two weeks but now it happens every day.
TIA
michelle227
michelle
North Texas/South Canada
Badlands 2dr 7spd/ Mercury Grand Marquis/ Jaguar X-Type/ Fiat Spider
How old is the battery? Reason I ask is I've had a couple of non-Bronco vehicles that did squirrelly things as the battery got low...
Ninjak
Miami
As @michelle227 said, this happens when your battery gets lower on the charge. It does it to help save battery life.
I have several Ford vehicles, and it has happened to all of them if the vehicle sits for a while, or the battery is starting to get low on charge.
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
It's 100% based upon your battery's state of charge. Either go for a long drive or put a charger on it for a few hours. If that doesn't help you need a new battery.
Draughon
Daylon
Dallas
BMW 4-Series
Means your battery is about to die. Get a new one.
Squirrel13
Brad
KY
A weak battery is usually the first suspect It doesn’t have to be a low battery though. There must be some kind of timer for days without a start. Both my 24 Bronco and my 20 F350 often sit for weeks at a time. Both are plugged into NOCO Genius 10s. When I went to Norway for 2 weeks both vehicles gave me remote features disable in Fordpass.
You are right, there is a timer regardless of voltage for inactivity - somewhere around 10-14 days
TheKim
Kim
Ford Bronco why? Remote Features Disabling 1000006944
Your battery will appreciate it. Just be sure to use AGM mode.
