Why No Published MPG ?
Drex
Jake
Yeah, while The Squash is a nice look, the added cost to get it, the field economy hit (most annoying will be the range with the small fuel tank), tire replacement costs, on road driving dynamics, you know... the practical stuff, was enough to keep me on 33's. All that expense for just the small difference between where 33's aren't enough and the 35's aren't enough, I won't be pushing it harder then the 33's would work anyway. Hell, not putting the big dancing shoes on my Badlands will save enough to pay for a year's worth of fuel. When fuel gets relatively high again, Squatchers might not be driving around so much.
Southern Girl
1974 Bronco/2024 Wildtrak
I have never really cared about MPG until I ordered a Bronco with a 17 gallon tank! Lol
That is going to be a major downer for me. I have a huge tank in my truck. I hate stopping for gas.
Southern Girl
I drove a diesel F250 when diesel went ridiculously high under a former admin. I just absorbed the costs. I didn't drive less. How am I supposed to drive less when I have to go to work to pay for this, anyway? :LOL:
Drex
Jake
I hear you, it doesn't matter how much fuel costs, I have to have it. There will be less discretionary trips, especially if folks have a second vehicle they can use. I also (since day one) know that a fairly high number of people will trade these in almost new because they are rougher, harder to get into, and far less economical then they anticipated (if they thought that far in advance to anticipate at all). They will ditch these while still hot in the market, within 18 months I would guess. There are a lot of non-Wrangler buyers and it will be a bit of a shock. (My limited experience is in a JK, so I will be pleasantly surprised by the Bronco, lots of people won't.
  • Like
Reactions: LMB
Onthegas
Roger
Harlem Georgia
Basemansquatch 5/9/22
Not sure how this might translate to Bronco but I saw Bronco Sport window stickers at dealer today. Both are mannequin demo/loaners. Badlands (Iconic Silver looked good) with 2.0 eco boost/automatic combined 23 mpg. Outer Banks (Area 51 looked bluish) with 1.5 eco boost/automatic combined 26 mpg. Your mileage may vary. Thinking in the teens combined mpg full-size Broncos?
Ford Bronco Why No Published MPG ? 1161B7DD-4494-4E5D-93BC-8632AAB84E54
Ford Bronco Why No Published MPG ? C5FCF1B3-4AC6-4EC1-9C71-81858A570787
NCOBX
H2 Hummer, Holden Commodore
Not sure how this might translate to Bronco but i saw Bronco Sort window stickers at dealer today. Both are mannequin demo/loaners. Badlands (Iconic Silver looked good) with 2.0 eco boost/automatic combined 23 mpg. Outer Banks (Area 51 looked bluish) with 1.5 eco boost/automatic combined 26 mpg. Your mileage may vary.
Really? The 2liter combined is 23? You could get better than that out of a V8 in something that small.
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
If you want good gas mileage get a 8k Prius to go with your bronco.
unfortunate
NA
Using fuelly as a good real world mpg guesstimate. I think the bronco 2.7l will get the same mpg as the F150 between 18-19mpg avg. The ranger has a range between 19-20 mpg avg..but I think the bronco is heavier so I’m guessing it’ll be about the same as the 2.7l as well between 18-19 mpg.
F150 with 2.7l v6
Ranger with 2.3 4cyl
Dillhole
Andy
Van down by the river
2012 Jeep Wrangler 2dr
As long as it gets the same or better than my Jeeps 10-12 in the winter and 14-16 in the summer I'll be happy.
Wizard1183
Lafayette
2014 Sierra/ 2010 Camaro 2SS
With the Sasquatch package I’ll be happy if my 2.7 pulls 20mpg on the highway.
Most likely 17-18mpg V6 SAS I’d bet. 2.3 with a 10spd will get around 23/24 tops. Now of course they’ll tell you city 20/hwy24 on 2.7 SAS. But they’re always fudging numbers. Actual mpg is no where near numbers they pump.
Wizard1183
Lafayette
Yea but1, it’s NOT aerodynamic, it weighs 5000lbs, it’s 4wd, and it’s low gearing. Want to recalculate that number again?
NCOBX
It weighs between 3,400-3,700 lbs, it’s gearing is not low nor would it need to be with 29” tires. Regardless you don’t often see gearing numbers for front drive vehicles. And it is fairly aerodynamic and extremely low to the ground.
If my 5.3L V8 4door 4x4 WT can get 24-26 consistently on the highway then I can’t imagine why this couldn’t do better.
In fact I bet a small displacement V8 with cylinder deactivation would be nearly 30MPG (Corvette MPG numbers)
Wizard1183
Lafayette
Im def calling bs on your 5.3 4dr 4x4 getting 24-26. I have a 2014 Sierra 4dr 5.3 2wd and I get 17-19mpg hwy. if you’re truly getting that? You’re doing 45mph on a 70mph interstate. 🤣
NCOBX
You’re driving an LS based 5.3L, try an LT based where they actually designed the engine for CD and the engines have DI. Totally different engine designs.
On my trips to Memphis I regularly have a 100 mile stretch where the roads are flat and the speed limit is 65 where the truck edges over 30MPG. Typical Hwy is only 24-26 unfortunately.
