Why did you order a Wildtrak?
BrentC
Brent
Calgary, AB
I sure hope forscan will work.
My f150 with high beams on will keep the dogs and lows on all the same timeim sure stopped us for making our trucks useful for the way we want to use them.
Bambi mode activated!
The wires should be everywhere for factory fogs..change H/light switch. Activate fog option and use all factory wiring?
Nah ford is dumb with thier combos they are providing.. I wait for my23?
Maybe by then they will have it figured out
In my 2001 F150 I could jumper the wires at the light switch to allow brights with fogs. I couldn’t hard-wire it on my 2009 F150 and didn’t even try on my 2019. Until I logged onto this site, however, I’d never heard of forscan before! šŸ˜‘. I hope that works.
I can’t blame Ford for following the law, and the switching is all done by PC boards, micro-relays and software to save costs. The auxiliary switches and external wiring are going to make things much easier...almost old-timey!
BroncoKong Jr.
Andrew
Not definite, but I see no reason why the same steps on the OBX won’t be able to attach to the BL model. I would be amazed if the same holes that accept the steps aren’t present on the OBX.
They'll fit just fine but you can't order them from the factory
Big AZ
adam
UsA
2021 Chevy 150o silverado z71
The only reason I see getting a Wildtrak over a similarly loaded Badlands is the Baja mode and black mirror caps which would have went nice with the painted modular top. If you load a Badlands like a Wildtrak you get the additional sway bar disconnect, rock rails, optional MGV interior, and washout floors. With the mic top, I just don’t see why anyone would want a Wildtrak unless they were hell bent on the Baja mode. How much better is the Baja mode than any of the other modes?
You can change the beauty rings. I plan on getting the real beadlock rings and ditching my beauty rings on my FE anyway. If I’m not mistaken, the fenders are mic black and don’t match the mic gray roof.
Let me know if you want to sell those painted black beauty rings off your wildtrak
Big AZ
adam
UsA
linbackr99
Todd
Vermont
2017 Raptor Crew
Because of the black wheels and accents and with the included Sasquatch and V6 the 60k-ish price point makes it a little less than an equally equipped BL - on which I can't get the side steps or black accents - or OBX, which comes in even more pricey and also has no black accents (but better interior options on both - the only thing that I'd prefer, but that's not enough FOR ME!)
BroncoKong Jr.
Andrew
The OBX configured like a Wildtrak is pricier than both a Wildtrak and a similarly configured Badlands?
linbackr99
Todd
Vermont
2017 Raptor Crew
And as I am sure has been mentioned - need to remove the rock rails . . . and then except for the disco what do you gain with the BL?
Baddie64
Paul
OKC
2005 Jeep Liberty, 2013 Ford Fusion Titanium
Like many of you, I am sure, I put a lot if thought into my order. I am in Canada so my Bronco was never going to be cheap and once my wife agreed, my budget could stretch. So, why did I order a Wildtrak? I am curious, why did you?
1) sway bar disconnect - after owning Wrangler and researching the Rubicon it seems to me that very few folks use the disconnect-ever. And while the Bronco system will be an easy system to use by comparison my research tells me that probably 90% of Badlands won’t get used for hard core rock crawling. And, the Rubicon trim on the Jeep is an aesthetic purchase as much as anything else. Another thought, the Taco does not have one and loses no offer road points.
2) bash plates - I can add these after market.
3) front bumper - I am going to buy a winch and upgrade the bumper anyway and I want the forward facing camera.
4) wash out floors versus carpet - 90% of my kilometers will be on road and trips. I think it will be quieter. Plus, the floor boards will most likely have the same mold as the BD so I am guessing we will be able to tap and die our own plugs a few months after delivery. Plus I live in an arid mountain area and should see a topless flood too often.
5) loaded value - in Canada, the pricing for the features seems like the Best value
6) gloss black wheels and accents - I ordered Velocity Blue and the ā€œblack on black on dark grey (fenders and MIC top) wheel, grill, side mirrors looks slick to me Versus other trims.
7) interior colour - the Tan might go the best with all the exterior colours
8) 12 inch screen and Lux cameras - after seeing the new 12 inch screen and having a B&O in my F150 and the surround cameras, my ego got the best of me and I am happy to need another year to pay off the extra price.
why reasons did I miss for you?
I may be way off base here, but if your activities with the Bronco necessitates aftermarket bumper, bash plates, and a winch, why would you not want sway bar disco? Just curious.
BroncoDymond88
New Jersey
'23 Bronco
I'm actually still on the fence but here are some thoughts that have me pretty nervous:
  • When spending 60k on this truck, I have a lot of trouble with not having the sway bar disconnect on the Wildtrak. The lower trim has "more features", and to me that's not right.
  • Also, the Badlands has 33's and since most times I'll be driving on the highway and not off roading, that probably makes more sense.
  • To spec the badlands as equal as possible to the Wildtrak, you're going to be spending quite a lot more money, and then will STILL need to do aftermarket mods (like changing out the grille and adding a tube step, wheels if no Squatch). I'm also already over my budget and not willing to spend more.
  • Also, if you do Squatch the Badlands, you can't get the tube step. Not having seen the truck yet I don't know how big of a problem that is but I do have some short passengers.
  • I'm also nervous about my AMB color choice, since the black decal wont pop the way I'd like.
  • I also do not want to give up the fog lights
Overall I'm frustrated with Ford's descision to not allow us to spec the wildtrack with more options like washout interior and sway bar disconnect, but it is what it is.
dgorsett
colorado
F250, Mustang, Explorer
So I could be like the super cool Big Bend guys and get the Sandstone interior, carpet, and Bumper with fog lights.
OK, I'm just a BB guy trolling.... :)
bajabronco57
Nor Cal
4Runner
I'll speak on this because I fall exactly into this category. I've been through the Rubicon, Moon Rocks, etc. I don't "enjoy" rock crawling as my primary means of off roading. I prefer dunes and desert. Nevada, Baja, etc. That is all higher speed rocks, brush, etc. I wont need the sway bar disco but I will need the extra protection.
I originally defaulted to the badlands thinking that was the right model for me but after thinking about it more and looking into the options and differences I'm going with a WT now. I will almost never use the Rock Crawl mode and I'd rather have the interior options the WT offers over it. I also think I'd use Sport mode.
Baddie64
Paul
OKC
I don't know if this is true or just a bug but on the online builder shows the Wildtrack Sasquatch is the only one that has the black beauty ring.
FE as well. My BL will as soon as I paint it. šŸ˜€
linbackr99
Todd
Vermont
2017 Raptor Crew
Yes. Not by a ton . . . but yes. And you still sacrifice a GOAT mode and (IMO) the better looking wheels and accents.
BroncoKong Jr.
Andrew
Wildtrak and FE are the only ones that get the black ring. Not coincidentally the trims with standard Sasquatch.
