Who's using the RC high winch mount?
TLO
Canada
youtube.com
2 door
I did a vid on the install to my 2024 Heritage.
Curious if anyone is using/not using frame horn braces with this or similar aftermarket winch?
Thoughts?
contented
Karl
Central Fl
BMW M2 Competition
Winch was on for 18 months and never used. Decided it would be wise to add the LOD brackets, which I did a month ago. I’m an old Boy Scout, generally always prepared. The brackets fit into that category. Now I don’t have to worry.
Ford Bronco Who's using the RC high winch mount? IMG_2427
Ford Bronco Who's using the RC high winch mount? IMG_2422
Ford Bronco Who's using the RC high winch mount? IMG_2420
Ford Bronco Who's using the RC high winch mount? IMG_2421
TLO
TLO
Canada
youtube.com
2 door
Nice!
So... Quick question. Did you have to pull the bumper to install 'em?
contented
Karl
Central Fl
BMW M2 Competition
  • Like
Reactions: TLO
XchrisX89
Wilmington, DE
Ford Bronco 2dr Badlands
How did you get the bumper mounted back on without the nut plate? I went to install these brackets today and ran into that problem. How did you get and hold the nut in place for the bumper?
UncleBuck
Washington
2011 Ranger XLT 4.0L - 4x4
Great thread right here all about the RC high winch mount. I'm running the now discontinued Tricky Motorsports frame horn reinforcements on my build. My build is all listed on like page 12 or 13. Many builds with ideas for everything you need on different winches, control box relocates, camera relocates, custom camera relocates, etc. Read the whole thread, it's really fantastic. I love my setup and although I haven't had the winch under heavy load for recovery, I've done testing and it's held up.
Ford Bronco Who's using the RC high winch mount? 1717641511565-w3
contented
Karl
Central Fl
BMW M2 Competition
I supported/balanced the bumper in place with my Harbor Freight Badlands jack. Then just used both hands. With out the jack, you either find a way to support it or have two helpers to hold it while you install the bolts.
Built2Wild
Bay Area
Motorcycle
Thoughts?
I highly recommend installing the frame horn brackets, I bought the LODs and used my winch twice. Once to pull myself from a mud pit and to pull a full-sized pickup with a trailer out of a water crossing. I watched your install video of the winch and was surprised that you did not use some type of frame horn brackets. Prior to installing the winch, reading through all the threads and seeing pictures, I knew the frame horn brackets were a must!
  • Like
Reactions: TLO
TLO
TLO
Canada
youtube.com
2 door
Shit, have people bent their frames without the horns??
Built2Wild
Bay Area
Motorcycle
