Who's a 7/19 build?
RubyRedGT
Greg
Pittsboro, NC
21 Bronco. Sold the 1968 and 2015 mustang GTs
Very cool, thanks! Gives me some more stuff to follow as I anxiously await progress :)
ChrisD
2021 Ford Bronco Badlands, 2021 Lincoln Corsair
Check out to see if your module has been activated here, data seems to will load in the arrow area while its running down the line:
https://www.motorcraftservice.com/AsBuilt
And the Sync Update can be seen on your My Vehicle Ford account once you've loaded your vin. it shows UPDATED before it's build, then seems to load a date once it's turned on in the Bronco and could take a day to populate based on what I witnessed last week on another thread.
Mine was in the same state on Friday when I checked it out of curiosity. Getting closer!
Debs
Debra
Claremore, OK, USA
2000 Excursion, 2006 Escape
Since I have nothing better to do and I don't feel like doing my actual work, I started just throwing info into a spreadsheet for the week of 7/19. Here's a screenshot.
Sorted by username, small "x" was just a placeholder for the blend date unless I came across a rotation number. Then it was replaced with that number. If it was blank, I couldn't find either a blend or rotation.
A few non 7/19 week users may have slipped in. And I'm sure I screwed some dates up haha.
Was just bored and I stare at spreadsheets all day anyway at work, so I thought, what the heck.
Edit: Will update periodically.
Edit2: Thanks for all the thanks guys, I just like things laid out in front of me. Oh, also what's interesting, it looks like late 7/20 early 7/21, the rotation numbers start back at zero. Thought that was cool to see. Also, I added what the rotation numbers look like in order so you can see where you stack up the day of.
Listed by Username in Alphabetical Order
Updated: 7/18/21 @ 2:23pm (CST)
Listed by Rotation Number in Chronological Order
I'm 7/22 number 1738.
I almost broke down and called my dealer to see what my date was. Luckily I checked my window sticker link at 11pm central time on 7/14 and it was there! I was glad I waited because it was so awesome to be surprised like that.
dgorsett
colorado
F250, Mustang, Explorer
So I'm seeing a spread of around 800/day. Does that sound correct? One or two shifts. Are they mixing in Rangers?
frogier
Frank
1998 Jeep ZJ Limited 5.9L
I'm a blend 7/23 rotation 2573
2 door, OBX
high package
carb gray
2.7
tow package
squatch
BDBrian1
Philadelphia
Ford Edge
Updated: 7/18/21 @ 9:48pm (CST)
My blend # is 0508. Thanks for the spreadsheet!
